Results 1 to 11 of 11
  1. I need a guide to recored of the real one player audio stream please.
    Or tell me how to do it?
  2. Member Grimey's Avatar
    May 2004
    Canada Eh?
    Not exactly clear on what your asking. do you have a .rm video that you want to extract the audio stream from or what?
  3. Member teegee420's Avatar
    Dec 2003
    Southern California
    I think the question concerns a streaming file.
  4. My guess is he wants to capture streaming audio to a file. Not extract it from a file already on his computer.
    Step one: place a tape recorder next to speakers....
    Just kidding, I don't have a real answer.
    "A beginning is the time for taking the most delicate care that the balances are correct."
    - Frank Herbert, Dune
  5. Member Grimey's Avatar
    May 2004
    Canada Eh?
    lol, thats was the first idea that popped into my head. :P
  6. Two Answers Buddy
    1) Record using something like Nero Wave Editor, Sound Forge or Cool Edit using either Sound Card Wave Out, Stereo Mix, or Use a Male to male stereo loopback cable and record through line in from speaker out
    2) Use Streambox VCR to capture the actual source audio and use Wiscroft Ripper to encode the real audio to MP3 or WAV or WMA.
    Feb 2004
    Vermont, USA
    Try Total Recorder. It works for me.
    Don
  8. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    total recorder is good for this, but see if you can select "Stereo Mix" as an input for Audacity - if so, you should record exactly what you hear from your speakers.
    I've had some soundcards that could do this, and some that couldn't.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  9. Member steptoe's Avatar
    Look for this :
    http://www.cocsoft.com/
    This will record what you want, I know it works as I've used it, but be warned it won't download ALL streams, the people who are streaming that data have done that on purpose so you won't rip their data
    If you have a full-duplex soundcard (can record and play at the same time) then there is loads of software that can do this as well, the hard way, in realtime
    The first method will download a stream in a few seconds, instead of realtime which most streamers manage the hard way
  10. Originally Posted by steptoe
    Look for this :
    Yeh I downloaded it, I'm trying to use it, but I just don't get it.
    You download the stream , then what?
    I want to turn the stream into a mp3 for burning..
    Is there a guide, help please...
  11. Total recorder works fine...thanks
