I recently upgraded my burner to a dual format model. I realize that I have to buy blank +R and -R, but is there a difference or way to burn +RW and -RW? I don't see anything in a setting for this with RecordNow Max and I am happy with using it vs Nero or EasyCD.
Thanks.
There is no specific setting in burning dvd-/+r or dvd-/+rw,the only thing you have to do is erase the dvdrw if you are going to use them again.
You burn DVD+/-RWs the say way that you burn DVD+/-Rs. The only difference is that you can erase a DVD+/-RW and burn again whereas you can only burn once to a DVD+/-R.
I don't use RecordNow Max (I have Nero and RecordNow), but RecordNow Max should give you the option to erase a DVD+/-RW that's been previously burned to. -
Thanks for the help guys. I realize that +rw disks can be erased and rewritten. What I was asking is if you can burn as -rw vs. +rw. I guess it does not matter, though and thanks for the help.
I guess I'm still not following what you're asking? Are you asking is there a difference in how you burn DVD-R(W)s versus DVD+R(W)s? Is so, no. You burn both discs the same way.
What format to use to burn video to DVD to be played in the UK (England)?
By jubbilee in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2011, 01:21 -
Burn from to DVD but what format to play on tv?
By Claxlast in forum Authoring (DVD)Replies: 5Last Post: 18th Mar 2011, 16:57 -
Are the AVCHD and H264 the only HD format to burn the HD DVD?
By coody in forum Authoring (Blu-ray)Replies: 7Last Post: 3rd Sep 2010, 22:47 -
how do i burn rm files to dvd format?
By sprilite in forum Newbie / General discussionsReplies: 3Last Post: 7th May 2008, 12:41 -
I've got an animation I did in MPEG format and I want to burn it to a DVD
By el_cid in forum Newbie / General discussionsReplies: 6Last Post: 3rd May 2008, 14:11
