ok so i figured out ( thank you sacajaweeda) how to unlock the controls in tmpgenc but it still outputs the same size file no matter what i change the bitrate to. i have also lowered the sound quality bitrate to 96 but no matter what i do it always outputs the same size file.
Stream type: MPEG-1 Video
Aspect ratio: 1:1 VGA
Frame rate: 29.97
Rate Control mode: Constant CBR
Bitrate: 500
Motion search: high quality (slow)
Stream: MPEG-1 Audio Layer II
Sampling freq: 44100
Channel: Stero
Bitrate: 96
any ideas as to what i am doing wrong? le tme know if you need more info and thanks in advance to any replies.
That problem sure sounds familiar to me, go to the Settings / System in your TMPGEnc, and check what "Stream type" says, I suggest change it to a VCD Non-Standard. That should fix the problem.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Check out these links...
https://www.videohelp.com/dvd#tech
http://dvd-hq.info/Compression.html
The first one is a link to the technical specifications for DVD-Video
The second one may help you to understand a little better how to use TMPGEnc to get the results you want."There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
Always glad to be of help
Best Regards,
Sefy Levy,
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
tmpgenc 2.5 plus problem
By DSLGuy in forum Video ConversionReplies: 1Last Post: 3rd Apr 2008, 15:38 -
Problem with TMPGEnc
By The Monkees in forum Video ConversionReplies: 2Last Post: 1st Nov 2007, 16:58 -
TMPGEnc Problem
By djkevyb in forum Newbie / General discussionsReplies: 3Last Post: 27th Sep 2007, 16:46 -
TMPGEnc Problem !!!!!!!!!!!!!
By homantam in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2007, 18:56
most helpful
