    May 2004
    Falun, Sweden
    Hi everyone..
    I have a question.
    I´m making a music dvd. For each song i have done a menu with the same backgroundmovie.
    How can I loop the background movie in the menu? The BGmovie are 10 sec long and the music thats playing is at least 3,5 minutes long. If i wan´t the background movie to loop, how can i do that? Now the movie stops after 10 sec, and the music continue.
    For the moment i solved it in aftereffects by making the movie 5 minutes long.. but there got to be another way to do this ? It´s taking too mutch place..
    The software I´m using is Adobe Encore and i can not change software.
    Thanks in advance /Polygone
  2. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    you had it right the first time - you can't loop the movie and continue the audio, you have to create a background loop that matches the length of your audio.
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
    May 2004
    Falun, Sweden
    okey..
    thats enoying... then i have to skip the bg movie! It would be so nice if there were any good solution for this..
    God!! Encore is really sooooo slow software.. the whole enviroment is slow.. specially when transcoding! I wait for the update 1.5 and hope they have done some good changes..
    thanks for your answear..
    //Polygone
