Hello! I simply need to know, which is the DVD player that supports VCD the best? It must be able to play all (or most) cd-r's. Of course, I'm looking for the cheeeepest.
I have an Apex DVD player from BestBuy. It plays Cdr's Cdrw's, DVD,SVCD,XSVCD,VCD,XVCD, Variable bitrates with video. 48000hz audio or 44.1khz audio. Pretty much everything I throw at it. It also plays MP3 cd's. 2 draw backs are the Menu you get for mp3 cd's only displays 8 or 10 letters. Sometimes when switching vcd's it may not play the next vcd correctly. I just turn it off and back on and it's good to go. It was $109 on sale at BestBuy. Apex ad-3201 model. I've also heard pioneer models are real good for vcd's as well I don't have one so I can't say.
My Apex-1500 works like a champ with VCDs, MP3 CDs, and anything else I've thrown at it.
IF you want a quick and easy solution that will play SVCD and VCD, go with the Pioneer DV-333 or DV-342.
Okay, you asked for which DVD player is the best for VCD. The answer is simple: Pioneer. Playback of VCD (on CDR and CDRW media), SVCD, SxVCD, SeVCD, DVD, etc. is absolutely superb! Compression artifacts are virtually non-existent.
Had you asked "which DVD player is the least expensive with average/mediocre VCD playback?" then the answer would be Apex.
Video from PC encoded and Burnt to VCD to Play on my DVD R Player
By dashas in forum Video ConversionReplies: 3Last Post: 16th Jul 2010, 22:15 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 20:32 -
GPX D1816SIL dvd player and I can not use it to play VCD disk.What should I
By nyankum in forum DVD & Blu-ray RecordersReplies: 2Last Post: 13th Jul 2008, 13:15 -
Upconversion DVD player w/ S/VCD
By Clessoulis in forum DVD & Blu-ray PlayersReplies: 2Last Post: 19th Feb 2008, 10:43 -
vcd playback - flickering picture on one dvd player, fine on another
By i_ming in forum Newbie / General discussionsReplies: 5Last Post: 21st Oct 2007, 08:41
