I am currently using Sonic DVD to capture my old VHS tapes. I use the Trim funtion (Not edit), to cut the start and end of the clips before I transfer them to DVD. I know that MPEGS lose quality when you edit them, but does this include trimming the start and end of the clip? If so, should I try to capture just the clip I want, and burn it to DVD without messing with it? Thanks
I don't think that trimming the MPEG in this way would reduce quality - it would be stupid to make an editing package that has to recode the entire clip to make changes.
The quality loss you may be thinking of is when you re-encode a movie, and so you introduce another set of comrpession artifacts into the image.
I think you will be fine. You can tell it is recoding the video if it takes ages to save changes - what it will probably do is copy the selection to a new file directly.
Hope this helps,
Cobra
How to significantly reduce size of an HD video with nearly same quality?
By oedipust in forum Newbie / General discussionsReplies: 47Last Post: 22nd Feb 2014, 21:54 -
Reduce MPEG-2 filesize without losing too much quality?
By yic17 in forum Video ConversionReplies: 10Last Post: 26th Oct 2012, 09:02 -
How to reduce filesize and to not lose too much quality?
By xxxThiefxxx in forum Blu-ray RippingReplies: 5Last Post: 9th Aug 2011, 09:48 -
Does mkvmerge reduce quality when removing subtitles?
By Moth Queen in forum Newbie / General discussionsReplies: 2Last Post: 25th Feb 2011, 23:06 -
how to reduce VOB quality..?
By chocolate_brownie in forum Video ConversionReplies: 7Last Post: 22nd Jul 2007, 20:22
