Results 1 to 14 of 14
  1. OT maybe but I was wandering if anyone here could advise me as I can't get any answers in any mac forums. I had a problem a few months ago with not being able to shut my imac down properly. It would just go to a screen that said 'You need to restart your computer' in different languages. The only way I could restart was to use the power button. Anyway after re-installing the System software it seemed to go for a few months. I then upgraded to Panther and recently I've been having the same problems. So far using Panther I've reinstalled my System Software 3 times. Each time it works fine for a while and then the same thing again? When I run Disk Utility it says there are no problems? Is there anything else I can try before having to buy something like Disk Warrior?
  2. Member galactica's Avatar
    Jan 2003
    Under Gateway to Midwest
    this screams bad/incompatible memory...........
    you add any recently?
  3. not recently but it has happened since I installed some a while back.
    Nov 2003
    New New York, Year 3000
    Run your hardware test CD. Its not a perfect test, but it can show you if something is wrong.
    If it isn't broken, take it apart and find out why.
    blog: deadsierra
  5. Just ran that Apple Hardware Test and it says everything is fine including the memory. My computer is shutting down fine now for the last few days after reinstalling the System Software. But I'm worried 'cause I know it's going to start again.
    My disc tray is also opening in a funny way. It kind of slowly opens and stutters as it's coming out?
    Do you think the shutting down problems would have anything to do with applications? I have Limewire (not professional just the freebie) but never really trusted that program?
  6. Master of my domain thoughton's Avatar
    England
    It might be to do with any kernel extensions (kext files) you've installed (the shutting down problem, not the drive door). I also occasionally get shutdown errors since I added a bluetooth dongle, so it could be caused by hardware too.
    Tim Houghton
    Website • Photography
  7. The only other hardware I have is a USB ADSL modem and a LACIE external drive. I had the problems before the LACIE but not before the BT Voyager ADSL modem. Are there any other checks or soloutions I can try?
    If it starts to happen again should I try taking the memory out?
    Nov 2003
    Absolutely. The Hardware Test CD can only tell you if the memory is bad, it cannot tell you for sure that it's good.
    blog: deadsierra
  9. Once again sorry for bringing this up in this forum but I don't know who else to ask. Thanks for your help.
    OK - I'll wait to see if it happens again. You definately don't think it's an application problem? It's just I don't understand how it's OK for like 1 month and then it starts having problems?
    Nov 2003
    If it keeps panicking on a restart, even after multiple re-installs, I'd think it was hardware based. I could be wrong though. Trying to remove the RAM seems like a good testing step.
    blog: deadsierra
  11. Member WiseWeasel's Avatar
    Jan 2003
    Silicon Valley, CA, USA
    Here's a (rather long) list of all the kernel extensions I have installed on my G5, which I'm pretty certain are just the default Apple ones. See if there are any extra ones you have (located in your /system/library/extensions folder, which you can go to by hitting command-shift-g in the Finder, and pasting in "/system/library/extensions"):
    ACard62xxM.kext
    ACard67162.kext
    ACard671xSCSI.kext
    ACard6885M.kext
    ACard68xxM.kext
    ATIRadeon.kext
    ATIRadeon8500.kext
    ATIRadeon8500DVDDriver.bundle
    ATIRadeon8500GA.plugin
    ATIRadeon8500GLDriver.bundle
    ATIRadeon9700.kext
    ATIRadeon9700DVDDriver.bundle
    ATIRadeon9700GA.plugin
    ATIRadeon9700GLDriver.bundle
    ATIRadeonDVDDriver.bundle
    ATIRadeonGA.plugin
    ATIRadeonGLDriver.bundle
    ATIRage128.kext
    ATIRage128DVDDriver.bundle
    ATIRage128GA.plugin
    ATIRage128GLDriver.bundle
    ATIRagePro.kext
    ATIRageProGA.plugin
    ATITVOut.kext
    ATTOExpressPCIPlus.kext
    Adaptec290X-2930.kext
    Adaptec29160x.kext
    Adaptec39160.kext
    Adaptec78XXSCSI.kext
    Apple02Audio.kext
    Apple16X50Serial.kext
    AppleAD741x.kext
    AppleADBButtons.kext
    AppleADBDisplay.kext
    AppleADBKeyboard.kext
    AppleADBMouse.kext
    AppleADM103x.kext
    AppleADT746x.kext
    AppleAirPort.kext
    AppleAirPort2.kext
    AppleAirPortFW.kext
    AppleAltiVecDVDDriver.bundle
    AppleBlower.kext
    AppleCPUThermo.kext
    AppleCore99NVRAM.kext
    AppleCore99PE.kext
    AppleCuda.kext
    AppleDallasDriver.kext
    AppleFCU.kext
    AppleFPButton.kext
    AppleFWAudio.kext
    AppleFan.kext
    AppleFlashNVRAM.kext
    AppleGPIO.kext
    AppleGossamerPE.kext
    AppleGracklePCI.kext
    AppleHWClock.kext
    AppleHWSensor.kext
    AppleHeathrow.kext
    AppleI2C.kext
    AppleI2S.kext
    AppleIntel8255x.kext
    AppleK2.kext
    AppleK2Driver.kext
    AppleK2Fan.kext
    AppleK2SATA.kext
    AppleK2SATARoot.kext
    AppleKauaiATA.kext
    AppleKeyLargo.kext
    AppleKeyswitch.kext
    AppleKiwiATA.kext
    AppleKiwiRoot.kext
    AppleLED.kext
    AppleLM7x.kext
    AppleLM87.kext
    AppleLM8x.kext
    AppleLMUController.kext
    AppleLSIFusionMPT.kext
    AppleMIDIFWDriver.plugin
    AppleMIDIIACDriver.plugin
    AppleMIDIUSBDriver.plugin
    AppleMLANAudio.kext
    AppleMPIC.kext
    AppleMacRISC2PE.kext
    AppleMacRISC4PE.kext
    AppleMacRiscPCI.kext
    AppleMaxim6690.kext
    AppleMediaBay.kext
    AppleMesh.kext
    AppleNDRV
    AppleOnboardAudio.kext
    AppleOnboardDisplay.kext
    ApplePCCard16ATA.kext
    ApplePCCardATA.kext
    ApplePMU.kext
    AppleRAID.kext
    AppleRTL8139Ethernet.kext
    AppleSEP.kext
    AppleSPU.kext
    AppleStorageDrivers.kext
    AppleSym8xx.kext
    AppleThermal.kext
    AppleUSBAudio.kext
    AppleUSBDisplays.kext
    AppleVIA.kext
    AppleVSP.kext
    Apple_iSight.kext
    AudioDeviceTreeUpdater.kext
    BootCache.kext
    CMD646ATA.kext
    CMD646Root.kext
    DSACL.ppp
    DSAuth.ppp
    DVFamily.bundle
    EAP-RSA.ppp
    GeForce.kext
    GeForce2MXGLDriver.bundle
    GeForce3GLDriver.bundle
    GeForceFXGLDriver.bundle
    GeForceGA.plugin
    HeathrowATA.kext
    I2CGPIO.kext
    ICAClassicNotSeizeDriver.kext
    ICAFWKodakProDriver.kext
    IOADBFamily.kext
    IOATAFamily.kext
    IOAudioFamily.kext
    IOBluetoothFamily.kext
    IOBluetoothHIDDriver.kext
    IOCDStorageFamily.kext
    IODVDStorageFamily.kext
    IOFireWireAVC.kext
    IOFireWireFamily.kext
    IOFireWireIP.kext
    IOFireWireSBP2.kext
    IOFireWireSerialBusProtocolTransport.kext
    IOGraphicsFamily.kext
    IOHDIXController.kext
    IOHIDFamily.kext
    IOKeyLargo.kext
    IONDRVSupport.kext
    IONetworkingFamily.kext
    IOPCCardFamily.kext
    IOPCIFamily.kext
    IOPlatformFunction.kext
    IOSCSIArchitectureModelFamily.kext
    IOSCSIParallelFamily.kext
    IOSerialFamily.kext
    IOStorageFamily.kext
    IOUSBFamily.kext
    IOUSBMassStorageClass.kext
    IPFirewall.kext
    ImmersionForceFeedback.kext
    KeyLargoATA.kext
    L2TP.ppp
    LogitechForceFeedback.kext
    MacIOGPIO.kext
    NKEMgr.kext
    NVDANV10Hal.kext
    NVDANV20Hal.kext
    NVDANV30Hal.kext
    NVDAResman.kext
    PPP.kext
    PPPSerial.ppp
    PPPoE.ppp
    PPTP.ppp
    Radius.ppp
    SharedIP.kext
    System.kext
    UltraTek100.kext
    UltraTek133.kext
    UltraTek33.kext
    UltraTek66.kext
    VLabKernelAdditions.kext
    VirtualAudioDriver.kext
    cddafs.kext
    com.aol.net.ppp
    iPodDriver.kext
    msdosfs.kext
    ntfs.kext
    smbfs.kext
    udf.kext
    webdav_fs.kext
    I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté."
    Jan 2004
    Finland
    Have you tried resetting parameter-ram? Guide can be found at www.apple.com, somewhere in support. It's easy solution to many problems
    Basically, process is somethin' like "press alt+command and somethin' during boot"
    Nov 2003
    Cmd+Opt+P+R for PRAM 8)
    blog: deadsierra
    Oct 2003
    Canada
    Also try installing OS X on the LaCie drive and booting from it (hold Option after turning it on). If you keep having panics then it's most likely hardware based.
