I'm trying to get 2 movies onto a single DVD, which I can easily do, as I'm currently doing another 2 movie to 1 DVD guide
But, I'm trying to get a method that supports subtitles as well as 2 movies on a single DVD, and I'm struggling
I use TMPGenc DVD Author for the autoring side of things, and in the past and trying other software to rip get the same problem with no subtitles
If this isn't supported (and if not why not !!), what DVD authoring software does support subtitles ??
I use :
DVDDecrypter
DVD2One
TMPGenc DVD Author
Nero
But for the latest tutorial I'm trying out another method using :
AnyDVD or DVDDecrypter
TMPGenc DVD Author
InterVideo DVD Copy 2
Nero (optional)
I need to get the subtitling to work for those that need it, and want 2 movies per DVD
Doing a DVD-DVD with subtitles is easy, but trying to get subtitles and 2 movies per DVD ain't so easy
So, now I'm after some help, so I can finish this tutorial with subtitle support (its finished without subtitles, but thats not really ideal for those that want/need subtitles)
Results 1 to 1 of 1
subtitles with TMPGEnc Dvd Author 3
By yoshiboy37 in forum Authoring (DVD)Replies: 3Last Post: 26th Dec 2014, 05:31 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
TMPGEnc DVD Author 3.0.5.149 - subtitles with italic commands
By lienny in forum Authoring (DVD)Replies: 9Last Post: 20th Jan 2009, 21:27 -
Question how to add subtitles with TMPGEnc DVD Author 3
By jimdagys in forum SubtitleReplies: 1Last Post: 5th May 2008, 18:24 -
'TMPGEnc DVD Author 3 with DivX Authoring' creates burnt-in subtitles?!
By abeelandig in forum SubtitleReplies: 4Last Post: 26th Jun 2007, 13:51
