Actually that stuff was off, I tweaked the hell out of it.. maybe I'm asking too much, then agaain maybe not, it's running much faster with WIN2000.![]()
https://www.videohelp.com/forum/viewtopic.php?t=221840
Results 31 to 37 of 37
Right! All the frilly little adjudstments it makes to the menus all the xp style stuff and all unnescessary services are cut off. Runs just fine, much more stable than 98 ever was.It will run faster if you tweak it, and shut off the frilly icon fluff"We were in barstow on the edge of the desert when the drugs began to take hold."
I used to run 768 MB ram, but had to steal 256 MB to repair another computer. Didn't notice any difference in performance on the first computer.
The only thing different was one program, After Effects. The 'Ram Preview' was about 5 seconds shorter.If it works, don't fix it. -
I was running WinXP on an AMD K6 300Mhz with 64mb Ram. It was slow, but still good enough for what it was used for.
Now I've got an Athlon XP 2500+ with 1gig Ram. I would never go with less than 512mb.
Unless, the only thing that the PC will be used for is wordprocessing and
e-mail. -
Like I said before, it depends on what you want to do. You don't need 2 gig of ram when all you do is e-mail and surf the net. Power users need more. I do videowork on both my computers.
My duron system has 512MB
My athlon xp has 256MB
Just stick with what works for you
I have installed xp on many systems with 128MB -
I've run my system on 256 for awhile now but I do notice that it struggles when I'm video editing/encoding etc etc - I'll be upgrading to 512 just to take the pressure off.
I guess in the end it depends what you use you pc for. -
Go with 512M.... you will noticed a lot less Disk Swapping.
I've read that 1G of memory is causing some anamolies with certain installs.
PC memory
By alintatoc in forum ComputerReplies: 17Last Post: 17th Nov 2009, 17:24 -
Vegas 8 - "System low on memory. You may be able to reduce memory usag
By sdsumike619 in forum EditingReplies: 12Last Post: 12th Nov 2009, 05:16 -
Memory
By ProducerHarley in forum ComputerReplies: 1Last Post: 3rd Dec 2008, 00:38 -
I just adeed another 2GB Memory and Total says 3.25GB Memory
By videocheez in forum ComputerReplies: 17Last Post: 11th Feb 2008, 06:19 -
I'm still trying to determine how much memory is in thus USB memory stick.
By zzyzzx in forum Off topicReplies: 4Last Post: 5th Nov 2007, 14:31
