I apologize if this has been asked before, I would use search but my internet is terribly slow today.
Normally, I DVDshrink and remove audio's and compress if i have to and the quality turns out just fine.
Now, I just read the tutorial on DVDRebuilder+CCE Basic Encoder, would this give me better quality than DVDshrink, or would it be the same?
Could someone enlighten me and skim through this tutorial, http://www.afterdawn.com/guides/archive/dvd_rebuilder_tutorial.cfm , and tell me if this would provide better quality for DVD9-to-DVD5 backups, or are there some missing steps that this guide is missing?
Thanks!
DvdShrink is usefull for low compression level: until 90% may be also better than CCE (that is a really encoder and not a simple transcoder like DVDShrink).
In the range between 90% and 70% the choice depends on the quality that you need.
Under 70 % CCE is always better and the difference is easy to notice.
Under 50% CCE is the only solution because DvdShrink (but also the other transcoders) give a bad...bad quality.
CCE requires long times for encoding: approx (depends from CPU) four times respect to DVDshrink.
Bye -
And the easiest way to incorporate CCE in a one-click program is with DVDRebuilder, in my opinion... Some effort is required to set up, but once you do, it's very simple with excellent results. I have now added it to my 'tool box' for those higher compression backups. For the lower compression ones, I still use DVDShrink.
Does dvdrebuilder use multi cores?
By the_man_one in forum Authoring (DVD)Replies: 4Last Post: 16th Jul 2010, 01:25 -
DVDRebuilder/HC Encoder making oversized file
By ricoman in forum Authoring (DVD)Replies: 8Last Post: 2nd Aug 2009, 16:10 -
No audio tracks (DVDRebuilder)
By stiltman in forum DVD RippingReplies: 3Last Post: 11th Nov 2008, 23:45 -
DVDRebuilder
By santino_avi in forum DVD RippingReplies: 5Last Post: 20th Jan 2008, 16:03 -
Please suggest which is better DVDShrink or DVDRebuilder?
By leinan in forum Newbie / General discussionsReplies: 4Last Post: 12th Jul 2007, 22:00
