Just wondering if someone could recommend a code-free/PAL to NTSC/macrovision free player that would work great with the Panasonic E80 recorder. With the Apex models, would I be able to play basically any disc from around the world(e.g. a macro-protected region 2 PAL disc) out to my Panny recorder and record it free of macrovision and NTSC converted? Will the Apex units play ANY DVD out with no macrovision? Should I go with an Apex, or can someone recommend another all-in-one unit to slave to my recorder? Help....please....Thanks,
Jonny
Cyberhome 300/400/500 players are far better than any Apex. Only flaw in Cyberhome is the 300 will not make 352x240 DVD look good. Others fine.
Also check out Nerd-Out.com....
So, Lordsmurf, if I were to get a Cyberhome 500 right now, do the macrovision AND region-free hacks(which are the most accurate ones?) work on even players from 2004? Because yes, I'd rather get a new player easily at BestBuy instead of getting a few years old overpriced Apex off Ebay,etc. Thanks for your help.
-Jonny -
Originally Posted by Jonny
See the other thread for a similar question:
https://www.videohelp.com/forum/viewtopic.php?p=922363
Note: The Macrovision literature claims that only 40% of DVD players implement the CGMS/A correctly, so you may get lucky with the other 60% players with only Macrovision removed. Just connect the player with your recorder and try recording something even with Macrovision present. If there is no warning from the recorder, then you only need to remove MV, otherwise it requires removing both.
Video to iMovie from Panasonic DMR E80H
By cjc182 in forum MacReplies: 0Last Post: 20th Jan 2012, 19:20 -
Panasonic DMR-E80H issue
By mavphoto in forum DVD & Blu-ray RecordersReplies: 3Last Post: 8th Jun 2010, 19:10 -
Panasonic DMR-E80H Error messages
By JeffM in forum DVD & Blu-ray RecordersReplies: 38Last Post: 7th Oct 2009, 17:08 -
Panasonic DMR-E80H Setup
By thebrookela in forum DVD & Blu-ray RecordersReplies: 7Last Post: 24th Mar 2009, 14:37 -
Panasonic DMR E80H problem when recording..
By Gravelexpress in forum DVD & Blu-ray RecordersReplies: 1Last Post: 27th May 2008, 09:36
