Hi!
I had a Norcent DP300 for about 2 years after it started skipping and also got a problem with the tray eject. Now I need to buy another one, probably a similar one, my key requirements:
1. Under $75-100
2. Pal/NTSC convertable
3. Region free (or has an easy hack)
4. Supports VCD, SVCD, MP3
5. No problem with playing quality
Can someone suggest which players I could take a look at that are currently available in Canadian retail..
Thanks a lot!
Kuzzz
Daytek P871 at Futureshop or Best Buy is good. Look for the manufactured date, December 2003 or later will be fine. Read the DVD Hacks at your left column how to hack it. Good quality DVD player.
Sam Ontario -
I have a Philips DVD727.A lot of people like the Phillips DVP642 aswell.They support the formats your looking for.I would do a search and see what you like.My 727 is region free out of the box and Pal disks works great with the setting in the menu.
Thanks guys,
Just bought Philips DVD727 yesterday, works great, plays all I need, and also looks much better than my old Norcent. I checked out on Daytek as well, there was the last demo unit w/o remote in the Future Shop near me but I was not in the mood to check other FS locations and then shortly found Philips in Wal-Mart.
Kuzzz
Want to purchase good DVD Upconverting 2.0 USB Player in Canada
By scharfg in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Jan 2010, 23:50 -
Good PQ DVD Player
By mis3 in forum DVD & Blu-ray PlayersReplies: 24Last Post: 31st Dec 2009, 13:11 -
Good retailer to buy a camcorder in Canada ?
By Zetti in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 10th Dec 2009, 17:43 -
Looking for a Good Video Player Or DVD Player
By DJboutit in forum Portable VideoReplies: 1Last Post: 6th Jun 2009, 21:57 -
In need of a good DVD Player
By Jenn11803 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 7th Nov 2007, 10:48
