I have womple mpeg-vcr and use it for all my cutting and joining, but I have several files with the audio off sync, there is an option to adjust the delay with demuxed files, but I don't know how much to do, so basically I am going trial and error, which is alot of demuxing and muxing, What I am looking for is a player or other editor that I can open the file find the delay I need, then use mpeg-vcr to mux the files, my files are not standard mpegs (DVB sat streams) so most programs (TMPG) are really picky about them, thanks for the help
ps. Virtual Dub Mod is having problems with the files too
I was going to suggest Virtualdub MPEG2 but I don't suppose you'll have much more luck than with Virtualdubmod. What you could to is demultiplex your files with Womble and compare the lengths of the seperate streams using a media player for the video, and an audio editor for the audio. Goldwave is a good audio editor.
In fact you could even open the audio with Goldwave(or maybe even the mpeg file itself) and use the time warp effect to stretch the length to match the video, save as wav and then use FFMPEGgui to convert the wav to mp2. Finally, mux the new audio using Womble. This method may not work 100% of the time but just might in your case.
Re-syncing Audio/Video: Utility Recommendations?
By will7370 in forum Newbie / General discussionsReplies: 4Last Post: 11th May 2012, 08:24 -
help syncing audio .wav of music to video of musician
By tspnyc in forum AudioReplies: 6Last Post: 1st Dec 2010, 17:27 -
Newbie here needs help syncing audio to video
By blackwaterstout in forum Newbie / General discussionsReplies: 4Last Post: 24th Oct 2010, 07:19 -
Visually Syncing Audio with Video
By gonzalu in forum EditingReplies: 11Last Post: 17th Mar 2009, 19:18 -
Syncing spearate audio/video: Better to stretch/shrink video than audio?
By stantheman1976 in forum EditingReplies: 15Last Post: 16th Jan 2008, 04:14
