Ok, here goes:
I have divx that I have converted to DVD. It plays OK in my PC's drive using any DVD playback software, but my xbox (which I use to play copies as my main player doesn't like them) has problems. I get a nice widescreen picture, good aspect ratio but....the DVD appears to play back at twice the normal rate (bought DVD's play fine) with no sound. Here's the process I used:
Used fit2disc to get the codec info, bit rate and aspect ratio figures. This also generated the aviscript (cos I'm lazy about math)
Loaded this into CCE and tweaked some settings - frame rate still at PAL 25fps as it was a PAL divx. Converted it to m2v using CCE. Ripped the sound and converted it using virtualdub/ac3machine. Then I used DVDLab to bring the whole lot back together.
I checked the files play OK using my DVD software, and then burn them to DVD using RecordNow DX.
So....Anyone out there know where I have gone wrong? (tried it with two different divx movies - one PAL and one NTSC (using pulldown) both give the same reults.![]()
Results 1 to 1 of 1
Why won't the Xbox 360 playback .mp4 video
By smitbret in forum Media Center PC / MediaCentersReplies: 20Last Post: 9th Feb 2017, 08:52 -
Converting videos for playback directly on Xbox 360...
By kevinmd88 in forum Video ConversionReplies: 3Last Post: 17th Aug 2011, 23:09 -
Burned DVD playback on Xbox 360?
By cmcfalls in forum DVD RippingReplies: 3Last Post: 25th Mar 2011, 14:30 -
Jerky video playback on Xbox 360 (AVStoDVD)
By KKPHM in forum Authoring (DVD)Replies: 1Last Post: 2nd Apr 2010, 01:56 -
My last hope with .MP4 playback on xbox 360
By kanwar786 in forum Video ConversionReplies: 12Last Post: 18th Feb 2009, 12:05
