Just wondering if anyone can help I am sure I copied a slideshow onto a cd for a friends wedding with "fit to music" and all, from iphoto about 12 months ago but since then I have bought ilife 3 & 4 and this option dosen't seem available, I have tried toast 6 quicktime version of slideshow and I dont think much of it as it is a quicktime movie not a real slideshow like the iphoto slideshow
someone has asked me to put some photos together with music on a cd and I said yes thinking I could do it on iphoto, WRONG!! any ideas, was this able on earlier versions of iphoto?? are there other apps that will do it for cross platform?
Results 1 to 10 of 10
I am confused about what you are asking.
Does iPhoto 4 have slideshow option - Yes
Does iPhoto 4 let music play during slide show - yes
Does iPhoto 4 have "fit to music" option - Unsure, i dont remember where it was with v3 but if you click SLIDE SHOW on the bottom tab, then MUSIC you get all the music options for that slideshow -
Can I save my slideshow to a disc with music, to give to someone else?
yes
click slideshow then click the MUSIC tab and choose your music you want. -
I know how to make them and play them, I want to copy them or burn them to cd, to give them to other people.
If you want to give an iPhoto slideshow to someone how you do this depends on their system and software. If they have iPhoto you can copy the stills and music to a disc and have them import all the files, then they can run it. iPhoto does not produce an independent slideshow in its own format. If you want a self running show, regardless whether or not they have iPhoto, then you have to make a QT mov or a web page. The iPhoto QT export option makes a very high quality, very small slideshow w/music if you like. This will run on any computer with QT player installed. (you could even include the PC and Mac versions of QT on your disc) The web option is really for online work and is manual advance - but doesn't actually need to be online to function.
There is really no other option using only iPhoto.
Norm -
I think iDVD4 can import and burn iPhoto slideshows...not sure about the "fit to music" option.
If you need to put it on CD, you can make the QT movie option in iPhoto mentioned above by using File>Export ... then select the QT tab ... but you will have to manually set the slide time to fit the music. You might also look into SnapzPro for saving iPhoto slideshows. -
Yes, CB is right. Forgot about the iDVD option. You can burn a dvd of an iPhoto 4 slideshow. You can of course just make a slideshow in iDVD also.
Norm -
Sorry for my delay in reply, was out of town
my mistake, i thougth you wanted to share your slideshow as in show it.
I dont recall a burn slide show optoin in the older iPhoto's. the only way i know to do it is to use iDVD and burn it that way
[beta] Bolide Slideshow Creator - Free AVI/MKV/WMV slideshow maker
By bolide in forum EditingReplies: 5Last Post: 30th May 2012, 04:18 -
Conversion errors in dvd slideshow gui during export burn to disc
By outdoorsyisin in forum Authoring (DVD)Replies: 2Last Post: 16th Mar 2012, 12:29 -
Burn photos slideshow into a disc–what’s the difference between DVD and CD?
By coody in forum Authoring (DVD)Replies: 5Last Post: 12th Oct 2008, 23:24 -
Need to have a DVD slideshow & photo files on same disc...
By Dr. John in forum Authoring (DVD)Replies: 8Last Post: 8th Jun 2008, 02:16 -
Mpeg4 AVC H.264 viewer for iPhoto/Quicktime
By rajupatel in forum ffmpegX general discussionReplies: 2Last Post: 30th May 2008, 17:14
