  1. im converting a multi episode dvd to xvid by autogk. right now im doing a trial encode on one episode, i just ripped the single episode out of the dvd using dvddecryptor and i loaded the folder in autogk, set the size and its doing its job now. the question i had was, my dvd has 4 episodes on it. now i can rip out the 4 episodes into separate vobs and encode them separately from 4 different folders but is there anyway to do it from one folder ? for example. when i rip one episode out to hd it saves it into the video_ts folder as VTS_01_1.VOB. i can load this into autogk fine because there is only one file in the folder so it will encode that episode fine. now what about the other 3 episodes ? can they be in the same directory as VTS_01_1.VOB or do they have to be all separate folders and i choose each folder and set everything and add them to queue till all 4 are in queue and then let them encode ? confusing question huh ? i'll try to rephrase if no one understands it. thanks.
  2. I think you need to use separate folders.
    This is from the AutoGK tutorial located within the program directory:
    "Here's an anime DVD with 4 different Episodes in 4 PGCs. The longest one is chosen by default, but you will want to open the other VTS's to track down the other Episodes (as shown here), and perhaps decrypt them in a different order. You should set up a different folder for each Episode."
    You need to rip in IFO mode
