Is Adobe Premiere 6.5 worth $150 ?
if you are into video editing and do it often, then yes... it is a great program and i love it! the only thing i wish is that it had more effects to use for transitions and whatnot...
-mercSYSTEM SPECS:
: Abit NF7-S v2.0:
: Corsair 512MB XMS DDR3200 :
: AMD Athlon XP 2600+ at 2.01 :
: 80 GB WD HDD 8MB Cache :
: Antec LANBOY Case 350w PSU + 2 80mm fans :
: Sapphire ATI Radeon 9800 Pro 128MB :
: LiteOn 4x DVDR/RW : -
yes. unless you wanna pay more than a few hundred dollars for the new versions.
In my opinion, yes. I have owned V 6, 6.5 and now Premier Pro. If you are willing to invest the time to learn, it will do amazing things.
Nope. (it's boring and no fun and very overpriced)
I prefer WinProducer 3.
Lotsa fun. more flexible(for what I want).
And renders AVI files much faster. -
I have used Photoshop a lot, so I think I could get the over all idea of premiere. But I need video quite a few video "filters" and stuff, so is it still good? and would anyone happen to know the filter for toning down the light, or what ever they use in movies today?
thanks -
gamma?
brightness ?
luma?
clip high of luma?
contrast?
RGB levels ?
take your pick"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Can you import from Adobe After Affects to Adobe Premiere Pro?
By Devilsadvocate in forum EditingReplies: 9Last Post: 29th Feb 2012, 22:43 -
Adobe Premiere Elements
By willmington in forum Newbie / General discussionsReplies: 5Last Post: 5th Jul 2011, 04:14 -
Adobe Premiere 1.5: Adobe Media Encoder: Frame size and scaling?
By vid83 in forum EditingReplies: 2Last Post: 30th Nov 2008, 04:17 -
Transition for Adobe Premiere
By traxstar in forum EditingReplies: 4Last Post: 25th Feb 2008, 21:05 -
Adobe Premiere Elements 4
By pepegot1 in forum EditingReplies: 12Last Post: 28th Sep 2007, 11:59
