Hi all
Wondering if someone could help me out. I have a bunch of files that have been recorded on pvr format. They have then been onverted into mpeg format. I would like to put these onto dvd, however the res/frame rate etc is not suitable for dvd. Can anyone recommend a program that can quickly re-encode or change the file to suitable dvd specifications?
Also, once this is done I would like to remove some sections from the mpeg file (ie adds, start and finish) Wats te best program for removing sections without then again re-encoding. Or is their a program to do both of these steps in one???
Cheer
Jess_0z
you should really edit before encoding - but mainconcept or tmpgenc or procoder will re-encode your files ...
mpeg-vcr can edit them after if you want to"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
DVD to an edited MPEG-2 file with MPEG audio: Trouble/please help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 21Last Post: 9th Aug 2011, 09:52 -
MPEG encoding for DVD
By BraDave in forum AudioReplies: 4Last Post: 4th May 2011, 00:34 -
cut one MPEG file to many small mpeg file automatic
By Cazz in forum EditingReplies: 2Last Post: 8th Aug 2010, 12:11 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36
