I'm doing some editing on mpeg 2 files and I don't want to lose the 6ch sound. I am using Womble mpeg2 vcr because it will save your edited videos without re-encoding or loseing your 6 ch sound. But it is getting very buggy and is starting to drive me insane![]()
Is there any other editors out there that will do the same without the bugs?
Vitec DVD toolbox Video Clip Mpeg 2 Pro will edit mpeg2 and ac3 files with out re-encoding either one .. though with ac3 it will only cut them - not combine them .. , with mpeg2 it will fully edit them frame or gop or nearest I frame method (you choose) ..
good luck finding it though -- but still one of the best programs out there for this .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
sony vegas 4 with dvd architect works with 5.1 (make sure u have dvd architect and not regular vegas). i dont know about vegas 5.
ulead dvd workshop 2 supports 5.1 as well, but i use it only for authoring, not editing. -
Originally Posted by choirislife923
vegas will not edit mpeg2 (without re-encoding) and will not import or edit ac3 files either.. though of course it can create both .. so that doesnt really answer the first posters question ..
premiere pro now has a plug in which enables editing mpeg2 without re-encoding (by main concept) .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Originally Posted by BJ_M
thats weird...when i capture with my tv wonder, i record in mpeg2 then load into vegas for editing and it works fine. are you sure its not in .vob but .mpg? vegas has issues loading files with a .m2v or .vob extension. -
when you load a mpeg into vegas (which has to be in program stream or a VOB or a transport stream) .. and try to edit it -- vegas will ALWAYS re-encode it... no doubt of that at all
oops...i thought u meant it wont load in vegas. wow, i never knew that.. -
How about Ulead Media Studio Pro 7. You can create all kinds of different video files with the ability to customize the rendered output. It has dolby AC-3 but I haven't used it yet.
http://www.ulead.com/msp/compare.htm
Can TMPGEnc 4.7.7.307 XPress support output 5.1 Channels???
By JackyWang in forum DVD RippingReplies: 2Last Post: 17th Apr 2011, 22:37 -
Programs that support .ass
By Spudwiser in forum Authoring (DVD)Replies: 2Last Post: 29th Jul 2010, 09:25 -
Editing Programs.. Hopefully freeware
By sgt_hanky in forum EditingReplies: 2Last Post: 9th Dec 2009, 06:09 -
Programs to Produce Very High Quality FLV Output Files
By devilcoelhodog in forum Video ConversionReplies: 2Last Post: 25th May 2009, 00:10 -
Do any of these editing programs work well?
By 392 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 11th Jan 2009, 20:33
