  1. I could not find a proper place to put this and it is a bit off topic so please redirect if it is improper.
    I have been reading and reading for the best options to build a machine for video editing. I searched and did not find any recent posts for suggestions.
    So could anyone help me to build a video editing PC?
    Questions...
    Should I go dual or single processor?
    What speed for the editing hard drive?
    Can you suggest a processor?
    Can you suggest a motherboard?
    I am looking to spend about $500 to build this.
    I have the following items or have access to them...
    200GB 7200RPM Western Digital hard drive
    512MB PC2700 Kingston RAM
    I can get a DVD burner for ~$75
    Standard floppy drive
    Firewire card
    -Machine
  2. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    Go to SatStorm's guide and scroll down about halfway to the "hardware" section. He addresses the PC issues for getting into the hobby:
    https://www.videohelp.com/forum/userguides/181153.php
    It is accessible by using the guides section in the upper left, then go to Articles, then the Newbie section, if you need to read more.
  3. Член BJ_M's Avatar
    Jul 2002
    Canada
    "computer" seemed like a good place to move it to ..
  4. Either
    Fast
    Faster
    Fastest
    200gig drive, nice size. Partition it wisely!
    512 RAM, up that to a gig, especially if using XP.
    Cheers, Jim
    My DVDLab Guides
  5. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    https://www.videohelp.com/forum/viewtopic.php?t=203419
    Read that first. Prices are cheaper now. Don't partition that 200GB, leave it as is and use it as a second drive. If you're going to do video work I highly recommend having two drives. Get another drive for a boot drive, whatever you want to pay for. 512MB of RAM is all you need for XP. Video apps generally don't use that much memory. The only reason I have loads of it is because I'm running a dozen things at once or doing massive RAM previews in AfterEffects.
    Read the above link, it will explain much...
    May 2004
    WA state USA
    CPU any amd 64 cpu will be great
    1 gb ram is good, 512 is ok u really want 1 gb if u can afford it, make sure u get pc3200 or higher u dont have to but its better if u do
