Hi guys,
My brother has a problem with his new PC. Since he built it, the audio port on the rear of the machine has always given a very tiny signal. The headphone port at the front is fine, just the rear one.
I have checked all the normal audio properties - it's set to two speaker stereo and all the levels are at maximum. What could be the problem here - maybe a damaged audio port on the motherboard?
Thanks for any advice,
Cobra
EDIT - Should have said that his motherboard is an Asus A7N8X-X.
the only help i can give, which is no help at all, is to buy an audio card. sorry.
Does it have the latest nForce unified driver set? In the newest version nVidia has some kind of mixerr utility with lots of settings to mess around with...
I assume you've already tried the obvious (mute, spkr volume, pc volume). Maybe check Asus forums for similar problems with that board? -
I've seen that happen when the insulating washer on the underside of the MB was left off. The aluminum mounting posts that the screws go into shorted traces on the backside of the board. This is especially common with DYI machines.Originally Posted by Cobra
Thanks very much for your replies. I just thought I'd let you know that we're sending it back for a replacement - the motherboard audio must be duff.
Thanks again,
Cobra
Need suggestions from pros on how to process low-level audio
By Asterra in forum AudioReplies: 2Last Post: 1st Jul 2011, 19:57 -
FFDshow audio decoder level is way too low...
By MidnightMike in forum AudioReplies: 2Last Post: 4th Dec 2010, 00:34 -
Audio is extremely low
By Nintendo Fan in forum AudioReplies: 0Last Post: 26th Aug 2010, 15:43 -
Need help with low level hum (audio attached)
By sdsumike619 in forum AudioReplies: 10Last Post: 22nd Aug 2010, 02:34 -
At wits end - Capturing with ADVC-100 and audio levels are extremely low
By Towncrier in forum Capturing and VCRReplies: 13Last Post: 18th Sep 2007, 18:04
