So far ASKA CD-R disks are the only ones that I can use to make VCDs that play on my Samsung 709. I'm running near the end of my supply and need another supplier. I've tried other manufacturers but have not had any luck so far. Samsung disks work according to the samsungmedia.com site however I have yet to find a supplier stateside.
The alternative is to use CD-RW disks and that may be what I'm forced to use. Hardly the best use of rewritable media.
Are you talking about the Memorex Pros?
I've tried the standard Memorex. They haven't worked for me.
It's peculiar, I can read them (the VCD's burned on standard Memorex) on my computer DVD-ROM drive but the Samsung complains that it isn't readable. I've burned VCDs on RW media successfully so I'm pretty sure of the process.
Thanx for the response. -
Another thought, and this one may be most significant. I am trying to use 80min CD-R media. Does anyone know if the Samsung 709 can deal with 80 minute media?
need to replace audio source with a different source
By sec1968 in forum AudioReplies: 0Last Post: 6th Mar 2011, 23:59 -
Backing up to Hard Disks-Not using Disks any longer.
By cal_tony in forum DVD RippingReplies: 5Last Post: 31st Dec 2009, 13:40 -
Cost of disks, blue ray or HD DVD, for data storage? Any good disks?
By overloaded_ide in forum MediaReplies: 16Last Post: 9th Nov 2007, 11:24 -
AviSynth not recognizing source type (source is animation)
By happypyro in forum DVD RippingReplies: 1Last Post: 5th Sep 2007, 14:48 -
Movies on the new HD disks... why?
By Marco33 in forum Off topicReplies: 10Last Post: 24th Jun 2007, 13:34
