Problem: My camera resets the timecode on my tape when recording. Why?
Is it because I view my footage mid way through recording? Then I go past the stop point, lose the time code of where I was at, and it then resets itself?
This reset is very annoying when trying to batch capture in Final Cut Pro.
I read the manual with my camera and came up empty.
Anybody got pointers?
Thanks.
Everytime you begin a recording on a blank tape, you record timecode as well. The only way to avoid this is to record on a tape that is not blank. Insert a blank tape, leave the camera lens cap on, and record over the entire tape. The tape will remain blank, but will have timecode on the entire tape.
Then no matter what you record, the timecode won't change.Hello.
Timecode skipping
By rds11 in forum EditingReplies: 1Last Post: 23rd Dec 2010, 09:24 -
No Timecode on my tape
By towarmforacoat in forum Newbie / General discussionsReplies: 1Last Post: 24th Oct 2010, 19:49 -
Burned in timecode - HOW?
By synaptic in forum Newbie / General discussionsReplies: 3Last Post: 20th Apr 2009, 23:41 -
Converting drop frame timecode to non drop frame timecode, and vice versa
By picrade in forum ProgrammingReplies: 1Last Post: 1st Mar 2008, 04:22 -
timecode messed up
By snafubaby in forum EditingReplies: 4Last Post: 20th Sep 2007, 05:00
