Hi guys I have been following this guide to convert my svcd movies to dvd http://www.dvd-guides.com/guides.php?category=othertodvd&name=tmpegencvcdtodvd but every once in a while the second part of a movie seems to go out of sync what could be causing it to go out of sync?
Results 1 to 9 of 9
I suspect the "Open sequence files as a movie option" ultimatly joins the source mpgs to one big mpg. I would not join the mpgs as this may lead to AV sync. Instead let your authoring software join them or even split them over multiple titlesets.
VCD is MPEG-1. MPEG uses time stamps in the file called PTS values. Some editing apps are what's called "frame accurate" and preserve the timing by only editing at certain points, like for example, the "I" frame.
Others will cut anywhere. Same with conversion programs. Some are sloppier than others when it comes to preserving certain aspects of the original.
Converting from MPEG-1 to MPEG-2 means your resolution will change, your bitrates will change, and the whole compression algorithm will be different. You may or may not be going from CBR to VBR. The only way it could be more "worst-case" is if you were also changing from PAL to NTSC. There's 3:2:2 pulldown, dropping frames and fields, interpolating fields and frames, inverting field order ....the list goes on.
My point is that there are many places where errors can creep in. The longer the video, the better the chance the error will develop into something that's unacceptable. This is especially true when editing or converting MPEG. It's also the reason many members prefer to do all their editing in .AVI and only convert to MPEG just prior to authoring the DVD.
My advice is to do a forum search here for threads on sync issues and see which software apps are being recommended. There are several that are cheap or even free
Do you mean the original is in two parts (on two (or more) disks)?every once in a while the second part of a movie seems to go out of sync
If so, I would let your authoring app do the joining, and not attempt it with something else.
You could join them with something like Womble, but you still may end up with audio out of sync.Cheers, Jim
My DVDLab Guides -
Thanks for the replies guys... Yeah svcd are split so I use to label cd 1 Video1.mpg and Video2.mpg like it says in that tuttorial and durring the conversion it would merge them but I have noticed some movies on the second part which would had been CD2 go out of sync, So I should just convert 1 by one then let TMPGenc authoring software take care of joining the movies? Also when I'm about to convert if I do one by one instead of letting the conversion merge them where it ask how much of they dvd I want to use would I use like 50% instead of 99.00%? Because if I do each conversion 1 by 1 of the mpg files when its done with it and I let it take 99.99% of disk space they will be about 4gigs each so I'm guessing I would give them 50% each instead?Originally Posted by reboot
Exactly. Unless you have some superior editing software (Sony SoundForge with mpeg plugin) to get the audio/video all in sync, just encode separately, and join in tmpgenc DVD Author (or whatever you author with).
I do about 90% of my work with two part files. (Don't ask why, ok?) and joining has always been an issue. I have had some success with joining avi in virtualdub, but the output is not consistent. Even frameserving doesn't solve it. Joining mpegs CAN work, if you use something like Womble. You can then load the product into Goldwave and use timewarp to get it in sync (if you have such software, and know how to use it).
In the end, I encode each video separately, rip audio, transcode to 48khz AC3, then import into dvdlab to author and burn. I have had far better success with audio sync using AC3 than PCM or some VBR .MPx
Edit to answer YOUR edit: Use the bitrate calculator. Input the total time of both parts, leave about 5% for authoring overhead, and you will know the approximate bitrate to encode at. I would start at about 47%.Cheers, Jim
My DVDLab Guides -
DVDLab.
MUCH better, in just about every way imaginable.
www.mediachance.comCheers, Jim
My DVDLab Guides -
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 17:56 -
Can I burn VCD or SVCD on DVD±R/W?
By Baldrick in forum Authoring (DVD)Replies: 111Last Post: 30th Aug 2008, 17:38 -
Newbie trying to figure out DVD to SVCD/VCD
By 4194 in forum Newbie / General discussionsReplies: 14Last Post: 26th Aug 2007, 09:34 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 17:56 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
by the way I use
