Hello, I want to change the bitrate of a file I have so it will work in a dvd player. Do I have to re encode the file again or is there a program that will let me change the bitrate without re encoding the movie? Thanx in advance.
Why are you sure it won't work as it is now?Originally Posted by dataspy
I'm using TMPEnc DVD Author to put it on a dvd right now, but it said it might not work. I'm going to try it, I just wanted to know if there was a way in case this doesn't work or if this happens again.
What exactly is the msg that TMPGEnc DVD author is giving you?Originally Posted by dataspy
Also how did you encode the file i.e., what bitrate parameters did you use originally? Also don't forget audio type and bitrate.
Bitrate Question
By x0pht in forum Video ConversionReplies: 5Last Post: 18th Jan 2011, 00:00 -
Bitrate question
By SuxRight in forum Newbie / General discussionsReplies: 3Last Post: 3rd Dec 2010, 01:45 -
Question about bitrate, spikes and Bitrate viewer
By sasuweh in forum Authoring (DVD)Replies: 3Last Post: 25th Oct 2010, 16:01 -
Bitrate question and two pass question
By cyberlion in forum EditingReplies: 17Last Post: 11th Oct 2010, 12:17 -
Bitrate question
By eclipse95 in forum Video ConversionReplies: 7Last Post: 10th Nov 2009, 23:03
