  1. This is kind of a unique error, so I wasn't able to find any info on it. I was converting an avi to dvd using DVD2SVCD and TMPGEnc. Encoding would get pretty far, but at DVD Author part of the process, the same error repeatedly occurs. Here is the error message from the DVD Author Log:
    DVDAuthor::dvdauthor, version 0.6.10.
    Build options: gnugetopt iconv freetype
    Send bugs to <dvdauthor-users@lists.sourceforge.net>
    INFO: Locale=C
    INFO: Converting filenames to US-ASCII
    INFO: dvdauthor creating VTS
    STAT: Picking VTS 01
    STAT: Processing C:\Documents and Settings\Paul\My Documents\My Videos\MPlex_Muxed_File00.mpg...
    ERR: Error opening C:\Documents and Settings\Paul\My Documents\My Videos\MPlex_Muxed_File00.mpg: No such file or directory
    I have encoded many avi files and this is the first time I have had this error. Is there anything I can do to fix this, I am at a loss? If it is the source, then I can accept that and move on.
    thanks,
    pdm
  2. Master of Time & Space Capmaster's Avatar
    Feb 2004
    Denver, CO United States
    Paul,
    Did the file somehow get the "read only" bit set? Check it by right-clicking and then check the properties.
  3. nope, the read only is not checked.
