I would like to know what program i need to convert img/.ccd/.cue/.sub files to a compatible mpeg 2 format?
.cue files are for bin files you can't turn that into a mpg.Originally Posted by venlib
.sub files are just a text file with subtitles and a timeline.
.img is a nero image isn't it ? You can mount that then rip the video and audio out of it.
.ccd don't know what that is.
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
CCD is just a control file for CloneCD, like a cue file in a way, the image will be in .IMG format, the .SUB file will contain subchannel data. CloneCD is sectorbased you see, the good old original one. Isobuster can open the IMG of CCD file, no prob. All those files you listed can be extracted with isobuster, the .SUB files are not used in that case (i think). Select extract -> filter M2F frames or something like that. Im sure you will find it. =)
What you have is a hybrid disc image probably created by Alcohol 120%. Without knowing the size of the img file I can't tell if it's a CD or DVD image. You can burn the image with Nero by selecting "burn image" from the file menu and using the cue file as the image source. You can also mount the image to a virtual drive with Daemon Tools and find out exactly what the image contains.Originally Posted by venlib
Normally you'd be right, but in this case the .cue file goes with the .img file, along with the .ccd and .sub files. People make these kinds of images to make them easier to burn by multiple burning programs.Originally Posted by VCDHunter -
Not much of an image if it's in 4 different files but I see what you mean - the 4 files are burnt at once by the burning prog. Or something.Originally Posted by teegee420
Think of the .ccd and .sub files as extra cue files(they're around the same size). They're just there in the event your burning app doesn't support .cue files.Originally Posted by VCDHunter
Feedback: vbulletin, [img][/img] tags not working.
By vhelp in forum FeedbackReplies: 5Last Post: 28th Jan 2010, 00:51 -
Burning .IMG Files to DVD
By niteghost in forum Newbie / General discussionsReplies: 6Last Post: 3rd Dec 2008, 19:13 -
HELP! how to convert video ts files to img
By underoath in forum MacReplies: 2Last Post: 14th Nov 2008, 07:32 -
Problem coverting some dvd files to a dvd that will play.
By nugent in forum DVD RippingReplies: 4Last Post: 12th Oct 2007, 10:03 -
.img files from medical cd
By RL in forum MacReplies: 5Last Post: 30th May 2007, 16:53
