I had a hard time finding this in the guides, so I am just wondering if there is a procedure to create a DVD on a CD-R? The video file I am going to burn will be less than 700MB, so it would be a waste otherwise.
"It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..."
700mb should be fine. Just author the disc as you would any other DVD. You probably already know this but Nero has a miniDVD template, but you'll still need to author the VIDEO_TS folder first.
Doesn't seem to work for mine, either. Most infuriating.
"It's getting to the point now when I'm with you, I no longer want to have something stuck in my eye..." -
I just burnt a mini-DVD using Nero6. Works fine on the PC, doesn't play in all 3 of my DVD players.
I normally just use TMPGenc DVD Author to author and convert to ISO, then Nero to burn. It plays on 1 DVD player but not the other.
I think you'll find that mini-DVD support is pretty scarce on most DVD players.If in doubt, Google it. -
Mini DVDs do not play on most older players. I have a Sony and Panasonic and they will not accept a mini DVD. But I have a cheapie Amphion Media Works player that plays them ok. If you are really into mini DVDs I would recommend that you get a recent player but be sure to verify that it will play the mini. Most stores, including Circuit City, will permit you to test a media before purchase.
Thanks. I will give it a spin, although I really have no compelling reason to do the mini-DVD other than wanting to keep a certain featurette.
How to Cut & Merge mini 10 part mini series?
By skorpinok in forum EditingReplies: 5Last Post: 8th Oct 2011, 10:41 -
Capture progressive mini-dv tape on interlaced mini-dv cam ?
By alip in forum Capturing and VCRReplies: 4Last Post: 8th Feb 2011, 18:27 -
Hardware choices: standalone mini-DV deck, or cheap mini-dv camera?
By SgtRauksauff in forum Newbie / General discussionsReplies: 3Last Post: 14th Oct 2008, 03:18 -
mini dvd help
By thigs in forum Video Streaming DownloadingReplies: 1Last Post: 25th Jun 2008, 15:50 -
Hd Mini dv tapes via SD mini DV camcorder
By imptech3 in forum Newbie / General discussionsReplies: 1Last Post: 13th Jul 2007, 03:11
