Hi ...
I have a "wmv" file (a music video) I want to put onto cd-rom. I understand I have to convert it to either avi or mpeg1. How do I do this?
Any help would be appreciated!
Ian
WMV is a type of AVI.
How do you want it on a CD-ROM? Do you want a VCD? Are you playing on a standalone DVD player? Does it support AVI? Just not sure how to tackle this question.
I think the most likely thing you're asking about is making a VCD to play in a standalone. You'd probably be best off using TMPGEnc - it's widely supported and there are lots of guides for it. If you look to the left-hand side of your screen you'll find a whole load of guides under "Convert" that will deal with what you need. I've found a good one to save you the trouble this time:
https://www.videohelp.com/tmpgenc.htm
Hope this gets you started,
Cobra -
sorry ...... yes - its to go on a cd-rom using Nero (I just called it a vcd) ... and yes its to play in standalone dvd player .... sorry!
Ian -
When browsing for your WMV make sure you move the "Files Of Type" slider to "all files".
Great! Found It! Thanks - Will try that & see what happens!
Thank you both
Ian
WebEx WMV to AVI or MPG
By jgq85 in forum Video ConversionReplies: 3Last Post: 19th Dec 2011, 10:57 -
AVI,VOB,MPG > WMV * New App
By VirtualDoobMon in forum Video ConversionReplies: 2Last Post: 14th Oct 2008, 20:42 -
Converting .WMV to .MPG and losing audio/picture
By frenchdb in forum Video ConversionReplies: 1Last Post: 29th Jun 2008, 21:42 -
Need help converting SCM files to mpg or avi or rmvb or wmv
By US Guy in forum Video ConversionReplies: 3Last Post: 6th Aug 2007, 02:01 -
Converting WMV to MPG
By Datahead in forum Newbie / General discussionsReplies: 3Last Post: 22nd May 2007, 15:08
