Hello all,
when encoding a small test clip exported from Final Cut Pro 4 as a non-self contained quicktime movie (the source material is in DV format), some scenes with camera panning looks "jumpy", i.e. the pan is not smooth. The output is supposed to be a VCD movie.
The strange thing is, when encoding the same clip in Toast Titanium, the encoded clip looks fine and plays back very smooth.
Do I need to adjust the settings in ffmpegx (just using the preset VCD at the moment), or is it a matter of changing the export settings in Final Cut Pro?
Thanks,
Ngawang
Process a MP4 (Quicktime) in a "smart rendering" way. Not to be re-encoded
By whenloverageswild in forum Authoring (Blu-ray)Replies: 1Last Post: 19th Mar 2012, 09:53 -
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV "Encoded date" metadata, a mystery?
By Gew in forum Newbie / General discussionsReplies: 5Last Post: 22nd Mar 2010, 19:58 -
Whats the "material/texture" of the White Injet & White Therm
By ty1er in forum MediaReplies: 4Last Post: 25th Jun 2009, 08:24 -
AutoGK question: Can I "Force IVTC" on "Hard-encoded NTSC&am
By BozQ in forum DVD RippingReplies: 11Last Post: 12th Jun 2009, 13:46
