Could somebody tell me the point of the AUDIO_TS folder? Of the many hundreds of DVD's burned, I've yet to see ANY file in this folder. Are there any DVD's which DO use this folder? Thanks
The folder isn't really necessary. It's mainly for DVD Audio discs.
Hi,
Just to go into this a little deeper. Some (mostly older) dvd player identify a DVD by their folder structure. Because technically the AUDIO_TS folder is a part of the DVD standaard, some players require this folder for the dvd to be recognized as an actual dvd.
In reality, i have never come across a player that didn't play if the AUDIO_TS folder wasn't there. Hell, i even have original dvd's which don't contain that folder..
Greetz,
pSyChO dAdThe difference between genius and insanity is only measured by success ! -
Originally Posted by Psycho_Dad_RulesThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
@daamon:
You're so right... i meant the AUDIO_TS folderThe difference between genius and insanity is only measured by success !
Probably a dumb burning question
By neroguy in forum Newbie / General discussionsReplies: 14Last Post: 7th May 2011, 04:34 -
Dumb PS3 Question
By wulf109 in forum DVD & Blu-ray PlayersReplies: 10Last Post: 4th Feb 2009, 07:56 -
Dumb PS3 Question
By wulf109 in forum Off topicReplies: 2Last Post: 3rd Feb 2009, 22:36 -
Really dumb USB 1.1 Question
By ahhaa in forum ComputerReplies: 4Last Post: 1st Jan 2009, 15:50 -
Dumb question about 768p
By winterwolfes in forum DVB / IPTVReplies: 28Last Post: 2nd Jan 2008, 16:50
