This is my first post. I have read through this site for a couple hours, and can't find a simple answer to my simple question. So, I'll ask all of you.
I want to rip certain scenes from DVDs and convert them into mpeg/avi or similar format that can be viewed on pc. I want these scenes to be from 1-10 minutes in length (Not the entire movie). I want them to be high quality, i.e., 720x480 or better, and with DVD clarity. They will need high quality audio also.
Size is not an issue, but cost is. I would like to do this with as little out of pocket expense as possible.
I have tried at least ten different program on the suggestion of many people, but none give me the quality I want. I have also seen alot of horizontal lines in the clips when converted (interlacing?).
So, that is my first post. I hope it fits the format. I also hope for a quick response from the MVPs or those with experiance doing this.
Much love!
Results 1 to 30 of 105
VirtualDubMOD
Used by itself for AVI
Used as a frameserver to TMPGEnc for mpeg1/2 -
Hi zeretul1,
I don't know if you've tried this already (would be useful if you listed the 10 that you've tried), but DVD2AVI springs to mind.
Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
If size isn't an issue than rip the entire DVD to your hard drive to one big VOB with DVD Decrypter and edit down the VOB to your liking with Womble MPEG VCR. Womble won't re-encode the video. No re-encoding = zero loss in quality.
I have tried DVD2AVI, and not only could I not get the audio to work, the video had the horizontal lines I discussed.
I tried the VirtualDubMOD with the same problem.
I used the DVD Decrypter, but instead of one big .vob file, I got 25. When I tried to use the Womble MPEG VCR program, it would not let me start without a PSN.
As I said, I am a newbie, and really want to learn how to do this. All help is appreciated.
Much love! -
If you ended up with 25 vobs, might we ask what operating system you are on, and a few specs on your computer?
If DVD2AVI crapped out on audio, check for an update to besweet. I know there's a few versions that did have trouble when coupled with avisynth.
Maybe try using the deinterlace filter in Virtualdub-mod (hint hint).
Womble has a fully functional 30 day demo. What's the problem with yours?Cheers, Jim
My DVDLab Guides -
I am running XP home on a home built pc. My cpu is athlon 2100+, memory is pc333 512mb, and vid card is nvidea geforce 4 ti4200 64mb. I also have 16x dvd-rom and 8x/4x dvd burner, both msi.
I will try and update DVD2AVI, and will try the interlace filter on the Virtuadub program.
As for the Womble program, I installed it and opened it, and the first screen I got was asking for the PSN. I have never used this program before. -
In DVD Decrypter go to Tools>Settings>File Mode>File Splitting = none.
For Womble go to file>open mpeg movie. -
Ok. I set the DVD Decrypter to make one vob file, but I am still getting nowhere with the Womble program. This is all I get...
Are you sure Womble didn't email you a PSN? That's how I got mine on their 30 day trial. Look for something from support@womble.com. make sure your spam blocker didn't get it, maybe.
um.... how would they send me an e-mail without my e-mail address. I downloaded the program from their download section, no e-mail address required.
OK, I got the Virtuadub prog to de-interlace(thanks for the hint), but I get no audio? When I rip from DVD with DVD Decrypter, I still get 23 files, but the main file has the main movie. The audio is encoded in that file, right? In Virtuadub, the only stream shown is "Input MPEG file" ,
so where is the audio?
Much love! -
Originally Posted by zeretul1"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
There are no AC3 files.
I have tried using the Mpg-vcr program, and am still getting interlacing.
Are there any how-to pages for using these programs? -
https://www.videohelp.com/faq#demultiplex
Me personally I'd just use DVDDecrypter to demux the AC3 stream. Another way would be VOBEdit."There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
Like I said, I'm a newbie, and I don't know how to demux the AC3 stream.
This is why I need the help. -
If DVD Decrypter generated VOB files for you, then you have video and audio in the files.
Within VirtualDUB, go to the menu and select File --> File Information. You can confirm what the video and audio (if any) in the file are.
If VirtualDUB tells you there is no audio, then there is none. You will have to go back to the DVDDecrypter step to find out why you have no audio (perhaps you use stream processing and removed audio?).The more I learn, the more I come to realize how little it is I know. -
In DVDDecrypter...use IFO mode, then enable stream processing, make sure your audio stream is checked and select demux. Then just tell DVDDecrypter where to save the files.
None of these things are working. I need a step-by-step, or more clear explainations of how to use these programs. I'm getting video with no sound, video with interlacing, files that won't open, etc....
I need help. -
Well according to the Virtualdubmod screen cap your vob has ac3 audio. Hopefully with the ac3 codec you should be able to hear the sound when playing back. Did you ever download the trial version of Womble afterall?
Yes, I got the Womble prog, but I have the same problems with that one as well.
Look, I am a COMPLETE NEWBIE, i.e., I don't understand the termanology, protocols, slang or program specs. I need a how-to guide or walkthrough to make these clips.
All I know is that I've seen clips that were 1-5min in length, 720x480 or better, DVD quality video and sound, and no interlacing. Their size was from 20mb to 80mb.
That is what I want to do. -
If the Womble program is able to open then use this guide to learn to make your cuts.
Have you tried playing the vob since you installed the ac3 filter? Can you hear sound now?
Originally Posted by zeretul1 -
Agreed.
I can use the Womble prog now, but I am still getting the interlacing, no sound, and un-openable files. I have figured out how to cut the section I want in the Womble prog, but not sure in Virtuadubmod. I never had a problem hearing sound in mpg2vcr, just the end file.
I'm not the most patient person, especially when I know there is something I can't do. But, I'll try to be patient. -
Ok. I can open a file in Womble, and am able to cut the section I want out and isolate it.
I have been able to make the editted file from Womble, and tose are the end files I was refering to.
I use RealOne Player for almost all my video playback, except Divx stuff. -
Try Mediaplayer Classic instead."There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke -
Originally Posted by sacajaweeda
Mpeg vs. Avi for VHS to DVD
By smartel in forum Newbie / General discussionsReplies: 4Last Post: 1st Jan 2011, 11:39 -
Please Help with converting AC3 in an AVI to an AVI with MPEG-1/MPEG-2
By twin1701 in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2010, 15:11 -
dvd to avi or mpeg
By AeR0 in forum Video ConversionReplies: 3Last Post: 22nd Jan 2010, 13:45 -
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 08:36 -
DVD to MPEG-2/AVI
By Nitro89 in forum DVD RippingReplies: 21Last Post: 14th Apr 2008, 15:17
