http://www.zipzoomfly.com/jsp/ProductDetail.jsp?ProductCode=173211
Of course, I wouldnt buy this. :P
Just thought Id post it if anyone was fixing to buy an 8x dual in the next few days, heres a chance to go 12x. I know BenQ and others are skiping 12x and going to 16x and dual layer/double layer is out and blah blah.
Results 1 to 14 of 14
*gags*
Artec?
I'd love to see just how crappy the quality is.
Sorry, I don't have much love for Artec and their products (being a former owner of Artec hardware). -
artec sucks no matter how u look at them, only good use for them is a paper weight
I don't think Artec makes their own drives. What rebadged kind is this? I used to think Artecs were made by Accesstek (Optorite) but at 12x, I doubt it.
i pretty sure artec makes there own drives, on my other comp i bought a mad dog 16x dvd that turned out the be a artec dvd-rom, POS it is but for 15 bucks it works for playing decent lol, so i would say yes they make there own drives
It says:
Writing Format
[DVD]
DVD Video, DVD-5, DVD-9, DVD-10, DVD-18, DVD+RW 4.7GB, DVD+R 4.7GB, DVD-RW 4.7GB (closed session), DVD-R 4.7GB
[CD]
CD-DA, CD-ROM XA (m1, m2f1/m2f2), CD-R, CD-RW, Bootable CD, Photo CD (single & multi-session), Video CD, Super Video CD, CD-Extra, Mixed-mode CD, CD-Text, CD-Graphics
So with DVD-18, it is more than just a Dual Layer DVD Writer! Blue Ray?Sam Ontario -
DVD-18 in an acronym that means a two-sided DVD disc with two layers of data on both sides of the disc
DVD-18 disc can contain upto 15.9 gigabytes of data on it (with 7.95 gigabytes on each side).
thats what a dvd that has full screen on one side and widscreen on the other is on
DVD-9 can hold approximately 7.95 gigabytes of data
DVD-10 means a two-sided DVD disc that hold single data layer on both sides
edit, the drive in question on this post isnt a DL drive, just dual format, meaning + and - -
It says "writing" format DVD-9 and DVD-18, it must be a DL capable!Originally Posted by koolaidwaSam Ontario
Capable of reading DL yes, but not writing. They have obviously messed up the specifications completely...Originally Posted by Sam Ontario
F.Y.I.
As handyguy just mentioned, the NEC ND-2510A with dual-layer burning is out, and is selling under $100. Here's one place that's selling it.
http://www.xpcgear.com/dvddvdrwdrives.html
Here's the spec for the NEC ND-2510A:
Data transfer rate (Read)
DVD: 12x CAV (max. 16,200 Kbyte/s)
CD: 40x CAV (max. 6,000 Kbyte/s)
Data transfer rate (Write)
DVD-R: 8x (max. 11,040 Kbyte/s)
DVD-RW: 4x (max. 5,520 Kbyte/s)
DVD +R: 8x (max. 11,040 Kbyte/s)
DVD +R9: 2.4x (3,300 Kbyte/s)
DVD +RW: 4x (max. 5,520 Kbyte/s)
CD-R: 32x (max. 4,800 Kbyte/s)
CD-RW: 16x (max. 2,400 Kbyte/s)
Media support
DVD-ROM, DVD-R, DVD+R, DVD-RW, DVD+RW, CD-ROM, CD-R and CD-RW with 80mm and 120mm diameter
According to the specs, looks like the dual-layer burning is only for +R
Cheers, -
Well, if you ever wanted an idea of just how BAD this Artec drive is...
http://www.cdrlabs.com/phpBB/viewtopic.php?p=117378#117378 -
The last Artec drive that was purchased for work was a rebadged BenQ.
I gopt this POS drive, its made by Artec themselves and dont support crap. Get the NEC 2500a and use Herrie's firmware to make it a 2510. Same drive except the firmware. Newegg h as the 2500 for around $69 or you can get the "Mad Dog 6-in-1" for about $50 after a mail in rebate as I did, it even still says NEC on the top of the drive.
HideOut
DVDRW 2016UI - DVD Rewriter
By DVD-Writeoff in forum DVD & Blu-ray WritersReplies: 3Last Post: 6th Sep 2011, 13:18 -
DVD-RAM 10x, 12x discs - who sells them?
By rjamesd05 in forum DVD & Blu-ray WritersReplies: 6Last Post: 15th Sep 2009, 22:56 -
Laptop rebooting during burning with Pioneer DVD-RW DVRKD08RS rewriter
By rock_king_my in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th Sep 2009, 05:04 -
LG GE20NU10 Super Multi Rewriter not showing up!!!!
By hassanthedon in forum DVD & Blu-ray RecordersReplies: 0Last Post: 27th Oct 2008, 10:06 -
Samsung Writemaster DVD Rewriter & Ripping DVDs
By rock_king_my in forum DVD RippingReplies: 1Last Post: 7th Dec 2007, 01:47
