Hi everyone,
Actually my tool has been around for a while and I even suggested to some people to use it, but I never did an announcement, so I guess it's likelly that some people missed. So here it goes:
DIKO is a one click DivX/XVid to KDVD/KSVCD (DVD/SVCD using the Kvcd.net compression tecniques) conversion tool. It works with many other softwares to achieve the best quality and efficiency possible in this conversion.
Some Features:
-Encoding via One Pass VBR Size prediction fully integrated, using CinemaCraft Encoder 2.66 or 2.67, ou using 1 or 2 Pass VBR throught Nic’s free encoder QuEnc (bundled in DIKO installation package).
-Does automatically all bitrate calculation needed.
-Convert audio to 48000/44100 automatically if needed.
-Do automatically framerate conversions from 23.976 to 25 fps and 25 fps to 23.976, including audio and subtitles. This feature also works with 5.1 audio.
-Automatic authoring with user-created menu via linux ported DVDAuthor or leave video audio and subs ready to be imported to other authoring packages.
-Automatic DVD image creating via MKISOFS and burning via DVDDecrypter if dvdauthor authoring is selected.
-Creates switchable subtitles from commom srt and sub files.
-Join subtitles for originally 2-CD DivX movies on the fly.
-Stops if Q Factor is too low (over 40), avoiding bad quality encodes.
-Automatically checks and fixes AC3 errors via AC3FIX
-Enables pulldown flag via Pulldown.exe automatically.
-It can fully work in background.
-Do AC3 encoding via SoftEncode or MP2 encoding via BeSweet
-Full avisynth script support, comes with latest Dialhot Script V4 for DivX.
-Takes care of the annoying Softencode dying bug.
-Crash Recovey
-Available in many languages, including: Brazilian Portuguese, Catalan, Danish, Dutch, Finnish, French, German, Hebrew, Italian, Polish, Speanish, Swedish.
-Automatically splits in two CDs if needed via Kwag's DIKuncizer.
-Can makes a KDVD/KSVCD out of DivX using only Freeware.
-Best Resolution Finder: Finds the resolution more suitable taking source and media space in consideration (only available using with CCE SP)
-Supports SVCD/CVD/Fixed subs in KSVCD mode
DIKO is available as freeware and there's a more advanced version called DIKO Gold for US$ 20. But the freeware version is fully functional and has all features described above.
Get it here:
https://www.videohelp.com/tools?tool=523#comments
Enjoy!
Results 1 to 9 of 9
Ohhh Errrr Missus?my tool has been around for a while and I even suggested to some people to use it
I think RabidDog may be slightly drunk tonight...Originally Posted by vmesquita287
New version out (0.6):
Check the ChangeLog:
-D2V support added to free version
-Added QuEnc templates
-Fixed Crash Recovery and Bugs with QuEnc support
-“Fool-Proof checks”: DIKO now prevents multiple instances and checks if avisynth is installed and it’s 2.5 branch.
-New Italian translation by thebepps1
Automatic video conversion
By scottyboy250 in forum Video ConversionReplies: 2Last Post: 18th Nov 2010, 16:48 -
add Disable automatic tool link to quick reply?
By lordsmurf in forum FeedbackReplies: 0Last Post: 12th Apr 2010, 10:51 -
Automatic video conversion/compression?
By cadunkle in forum Video ConversionReplies: 1Last Post: 12th Jun 2008, 14:46 -
Automatic DVR-MS to Divx conversion?
By frankmaster100 in forum Video ConversionReplies: 5Last Post: 24th Mar 2008, 10:43 -
Best DV to DVD conversion tool
By whenloverageswild in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 24Last Post: 2nd Nov 2007, 01:50
