Hi
Im a newbie and Ive got a question.
Im using Adobe Premiere 6.5 for editing and I have just finished a project. Should I use Premiere to encode to mpeg2 or do I get a better result if I get TMPGEnc and use that to encode?
Thx in advance
Hakster
well -- its a toss up , have you updated your PP6.5 with the main concept ugraded encoder (free) ?
they will do about the same quality - but the built in encoder will be faster.."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Thx for your reply.
No, I havent got the update but I will get it now.
Hakster
which is better Mainconcept MPEG Encoder or H.254 Encoder
By d_unbeliever in forum Newbie / General discussionsReplies: 7Last Post: 4th Aug 2012, 19:14 -
How it possible Video: X264 encoder with Matroska encoder extension?
By flash_os in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2012, 10:13 -
Your Best Video Encoder/Re-encoder???
By iqbal88 in forum DVD RippingReplies: 2Last Post: 15th Aug 2011, 09:09 -
Hc Encoder
By pcb in forum Video ConversionReplies: 12Last Post: 28th May 2010, 14:15 -
Error with Nero AAC encoder in XVID4PSP - "Could not open AAC encoder&
By TheViking in forum Video ConversionReplies: 2Last Post: 5th Nov 2009, 02:41
