Hey there,
I am working on a PAL DEFT conversion of an NTSC Interlaced TV show on DVD.
I have ripped all my files and am saving each block as an AVI with VirtualDubMod, however this leaves the AC3 audio track in the AVI file. Since I plan to stitch them together and encode them with ProCoder, I need the AC3 part to be deleted, because ProCoder thinks the file is corrupt with the AC3 part still in there.
I could simply use VirtualDub and choose No Audio and save the files again, but they're very large so space constraints mean I can't do this. Plus, this takes time.
So is there a program that will simply delete the AC3 part of the AVI file without transcoding? Thanks!
Originally Posted by Lyris
Originally Posted by Example.avs
You should now have your original avi file, and AVS script witht the same name, and your newly wrapped "_avs_vfapi" version of your avi file. Don't worry about space either because the vfapi avi file shouldn't be more than a couple of mbs in size. You can close the VFAPI Reader program right after conversion is done and test it by opening up the file in VirtualDub; since there was no processing of the video inside the avs script the video should look identical to your original avi file. A File > File Information should show video information and no audio information.
Originally Posted by SplicedAVIs.avs
I need help playing AC3 audio file with an AVI
By mark85h in forum Newbie / General discussionsReplies: 8Last Post: 18th Feb 2011, 15:04 -
Convert h.264 MP4 w/AAC 5.1 audio to AVI file w/AC3 5.1 audio for Xbox 360
By ycrazyy in forum Newbie / General discussionsReplies: 6Last Post: 14th Jan 2010, 15:25 -
I have an issue with cutting a portion of an avi file.
By darksniper in forum EditingReplies: 4Last Post: 9th Oct 2009, 20:23 -
mkv - deleting multiple audio tracks & subtitles - then convert to avi
By fme008 in forum Video ConversionReplies: 2Last Post: 24th Mar 2009, 06:12 -
Trying to Convert avi. (Dvix) with AC3 audio file to DVD Format
By carlos305 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Aug 2007, 08:54
