Hi all just a quick question, is it possable to do batch encodeing with nero vision express 2 ? if so then how do u do it ?
Thanks in advance....
does no one know how to setup nero so that u could leave it over night to encode a few films ?
I use to use TMPGE but everytime i use it, its all out of Sync when i use nero its perfect comes out the same quality as TMPGE it does take a little longer, but anyways thanks anyways
The thing with TMPGEnc is that it doesn't handle compressed audio well. You should always decompress the audio to wav first just to be safe. If your source file is avi, open it with Virtualdub, go to the audio menu and select "full processing mode", then go to the file menu and select "save wav". Use the wav file as the audio source in TMPGEnc. If your avi has ac3 audio you'll have to install the AC3 ACM Decompressor in order for Virtualdub to process it.
Batch file
By Anurag in forum ComputerReplies: 16Last Post: 19th May 2009, 12:27 -
How to Batch Process Using Avidemux? Or Batch Processing H264 .m2ts or .ts?
By forgotpassword in forum Video ConversionReplies: 0Last Post: 14th Apr 2009, 01:00 -
Batch converting...
By finey in forum Video ConversionReplies: 6Last Post: 31st Jan 2009, 18:01 -
Batch rendering
By TrupsT in forum Video ConversionReplies: 5Last Post: 5th Jan 2009, 01:21 -
Batch Transcoding?
By joelore in forum Newbie / General discussionsReplies: 5Last Post: 3rd Jun 2007, 17:42
