In http://www.vcdhelp.com/minidvd.htm is an image of a MiniDVD provided by http://www.dvd-wizards.com I downloaded it and burn it on a CD with Roxio CD-Creator 5.0
I put the MiniDVD Sample Disc and put it on the Daewoo DVG-3000N and it entered in file mode from there I open the Video_TS folder and played the VOB file. I could see video and sound.
Now that I Know that this Sample worked I need help with making MiniDVD my self.
I take my Sony DCR-PC5 and with Studio DV capture a 10 minute Avi Video. Then I take TMPGEnc 2.01 and load the DVD template, in Video Source and Audio Source I put the 10 minute AVI and on the Setting I tell TMPGEnc that the maximum bitrate have to be 5000.
After the MPG-2 file is made I goto MyDVD and select cDVD make a menu and burn the CD.
The CD works well with PowerDVD on the computer but on the Daewoo DVG-3000N only shows the Video not the Sound.
I read in this Forum that the audio have to be encoded to AC3 in order to work but I cant find a guide and I have a lots of already made MPG-2.
I Have a Pioneer A03 but If the footage is only 10 minute I dont want to waste a DVDR for that.
If any of you know the links on how to work this out please Reply.
Results 1 to 1 of 1
I was surprised an ip masker really really worked
By yoda313 in forum Off topicReplies: 0Last Post: 22nd Feb 2011, 14:49 -
Daewoo DF4100P
By hillneerg in forum DVD & Blu-ray RecordersReplies: 1Last Post: 19th Feb 2011, 11:06 -
I have tried many media converters for HD, none of them worked
By calande in forum Video ConversionReplies: 2Last Post: 11th Jul 2010, 20:02 -
Code Free does not work daewoo dvg 8300 se
By ramona in forum DVD & Blu-ray PlayersReplies: 1Last Post: 4th Feb 2008, 10:52 -
.MKV to DIVX worked but not really
By cabala in forum Video ConversionReplies: 7Last Post: 7th Oct 2007, 18:58
