I know this has been asked a few times; I have looked in search. However, no one seems to have posted a definitive answer...
How does one convert from WAV to AC3?
This is what I have done so far:
Converted from mp3 to WAV using Goldwave
Created 6 mono wav files from the above .wav file.
Now, how do I combine and convert into a single AC3 file? (5.1 DD, NOT DTS!)
If you know the answer, please share! If possible, with a step by step explanation of which tool(s) and which settings.
Many thanks in advance!![]()
You get Sony Acid pro, they have 5.1 surround plug-in
found here
http://mediasoftware.sonypictures.com/products/showproduct.asp?PID=704
there is free one that only converts to 2 channal ac3.
found here
https://www.videohelp.com/tools?tool=434#comments
Heres a website on diffrent 5.1 and DTS software
http://www.5dot1.com/equipment/ac-3_and_dts_software_encoders.html -
Originally Posted by Isengard
not been sold for many years"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
ffmpeggui is freeware, and works reasonably well, but it doesn't support the gain word, so if you use GoldWave to maximize the volume, it gets undone when transcoding the WAV to AC3.
The $29 AC3 plug-in for TMPGEnc DVD Author is what I use.
AC3 to WAV = Wav has no audio??
By RobV in forum AudioReplies: 5Last Post: 31st May 2010, 15:26 -
how to transcode from AC3 to WAV
By phpmysql348 in forum AudioReplies: 3Last Post: 7th Sep 2008, 00:46 -
how can we convert ac3 to wav?
By sumeshkri in forum AudioReplies: 6Last Post: 4th Sep 2008, 02:29 -
5.1 Wav to AC3
By markjwiggins in forum ffmpegX general discussionReplies: 0Last Post: 21st Dec 2007, 14:44 -
AC3 to WAV (MUST KEEP 6 CHANNELS)
By RushMaster in forum AudioReplies: 6Last Post: 17th Oct 2007, 04:03
