I want to convert a xvid file to put on a dvd,i've looked at the 'how to' guide posted on here which says i need to extract the audio first using virtualdub.
When i open the xvid file in virtualdub i get a message saying
"couldn't locate decrompresser for format 'XVID' (unknown)
Virtualdub requires a video for windows (vfw) compatible codec to compress video.Direct shows such as those used by windows media player are not suitable."
Can anyone help me please
Get the Xvid codec - under tools > codecs on the left.
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard.
VirtualDub -- XviD file size problem
By higgins327 in forum Video ConversionReplies: 8Last Post: 29th Mar 2011, 16:05 -
Divx/Xvid problem in Virtualdub (not mod)
By leeqk in forum Newbie / General discussionsReplies: 14Last Post: 11th Apr 2010, 01:18 -
Problem opening Xvid movies in VirtualDub
By wombat4 in forum SubtitleReplies: 9Last Post: 24th Jun 2009, 09:23 -
Virtualdub Xvid Decompressor problem
By unkown in forum EditingReplies: 12Last Post: 13th Aug 2007, 19:38 -
Problem with Divx/Xvid with Winamp and Virtualdub
By mekuka_pinasem in forum Software PlayingReplies: 5Last Post: 1st Aug 2007, 11:41
