ok...when u first capture a video from your dv camcorder, then u playback the original captured video, it plays smoothly (like 50fps) right?
but then after i edit the dv and convert it to dvd (mpeg2), the video plays back at 25fps (dont look smooth, its like 2 fields blend together and display at the same time). now i cant afford a dvd burner and i dont have a dvd player yet. but i am backing up and making a lot of mpeg2 videos to be ready to burn once i get one burner.
so i want to ask, when i burn the mpeg2 video to a dvd and watch it on tv, will i be watching the smooth (50fps like) video?
You capture at 29.97fps and your DVD will be the same(I'm assuming you live in North America). You're seeing interlacing because you are watching the video on a non-interlaced display(your monitor). It should look fine once you author to DVD.
Simple question on DVD+R DL discs/Capacity
By alegator in forum MediaReplies: 12Last Post: 19th May 2011, 04:52 -
simple question for experienced DVD player owners
By asmodeus718 in forum Newbie / General discussionsReplies: 4Last Post: 3rd Apr 2010, 22:02 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 22:38 -
AviAddXSubs simple question (hopefully!)
By vladman2nd in forum SubtitleReplies: 1Last Post: 8th Jul 2008, 01:01 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 21:10
