Has anyone tried these and knows who makes them for Target?
Don't know who makes them, but I've just backed-up my 25th disc with no issues
smb...share the music -
Comments like this are not to be trusted.Originally Posted by smb
If you have no idea who makes them then you have no idea how to read media codes.
Which also means you probably don't test your discs.
When I say test your discs I mean running a READ ERROR test such as the one built-in to NERO or by using DVDInfoPro or best yet Kprobe.
It could be that your DVD discs are playing back OK but that doesn't mean they are problem free.
Only testing them with one of the mentioned programs will tell for sure.
I have tested discs with DVDInfo Pro and NERO Scandisc for read errors and they came up perfect. When I tried to play the disc on a variety of drives however, it always had problems. I have found the NERO verification option to be more useful.Originally Posted by FulciLives
SMB, can you please find out the media code for louv68 with DVDInfoPro? -
The discs are CMC-MAG. A quick search for that media tells me others would suggest to avoid it...but my original statement stands....
25 backups...no issues (with my equipment)
Fulci...do you do the READ ERROR test for every disc???? I guess I've never bought any DVD-R's that didn't burn correctly. I have backed-up 100's of disc's and I have never had a coaster. I may just be lucky....but it's the truth nonetheless.
LOUV68 I hope this helps....smb...share the music -
Thank you smb,
I've not had good luck with CMC-MAG media so it's probably best for me to stay away from it. Wow, you've never had a coaster. I wish I were that lucky.
-LouV68
Help please! Internal Target Error when burning to DVD
By kylina in forum Authoring (DVD)Replies: 9Last Post: 4th Apr 2010, 13:49 -
Alpha channel video makes for a larger-than-target bitrate flv
By flvvideo in forum Video ConversionReplies: 1Last Post: 3rd Dec 2009, 11:10 -
AVI To DVD Which Target Format?
By Bunky in forum MacReplies: 10Last Post: 30th Oct 2009, 07:41 -
Optimal Video Bitrate and target DVD size
By src2206 in forum Authoring (DVD)Replies: 22Last Post: 24th Oct 2007, 06:54 -
Gear Head DVD+R?
By bevills1 in forum MediaReplies: 1Last Post: 8th Jul 2007, 12:56
