ok...i now i know wat is interlace video, here is my problem:
when i play the original captured dv video, the video plays nicely at 50 field per second, which is very smooth, but after i edit it or something, i output to avi full frames uncompress or any other format, the video will become interlace, as i know interlace is 2 fields sticking together, so when i play the output dv, the video is very jerky its only playing 25 fps per second.
but this doesn't happen when i play a dvd or avi downloaded from the internet. they are smooth. so how do i play a video with 50 fields per second on my pc?
by the way, i want to know after i output the original dv video to a interlace mpeg2, is the 50 fields still available or it is just 25fps without any field?
50 FIELDS per second is the equivelent of 25 FRAMES per second:
( 2 Fields = 1 Frame )
Your playing back your video at 25 frames per second, which is correct.
As to your interlacing issue, all DV video is interlaced, so you should expect it to play back as interlaced. Your video is probaly jumpy because your encoding the wrong field first. DV should always be bottom field first. If you get it wrong, your output will appear to 'jump', or 'jitter', especially on panning shots, or scenes with a lot of motion.Impossible to see the future is. The Dark Side clouds everything...
Converting DV to H.264 and comparing interlaced/de-interlaced
By amirh1 in forum Video ConversionReplies: 5Last Post: 23rd Jun 2010, 10:16 -
How to know if a video is interlaced?
By JLGUT in forum EditingReplies: 9Last Post: 20th Mar 2009, 16:40 -
Captured video is interlaced - Help?
By dave_van_damme in forum Newbie / General discussionsReplies: 8Last Post: 25th Feb 2009, 17:44 -
Video Advantage PCI: Interlaced Video/No Live Audio Preview/Other Questions
By acid_burn in forum Capturing and VCRReplies: 2Last Post: 8th Feb 2008, 21:03 -
How can I tell if a video is interlaced?
By cheerful in forum Newbie / General discussionsReplies: 10Last Post: 18th Jul 2007, 22:56
