How good (Or should I say bad ?!?!?!) is them to use while copying from VCR Stereo Video -> (S)VCD ?
http://www.msi.com.tw/program/products/mainboard/mbd/pro_mbd_detail.php?UID=344&MODEL=MS-6501
I better go SB Audigy perhaps ?
It has only 3 33Mhz PCI slots, that is some problems.
The built in AC97 is as good as the SB128. Not as good as an Audigy maybe, but at 224 or 384kbps stereo, I defy your ears to tell the difference.
If you were using Dolby 5.1 AC3, then you might consider a better card.Cheers, Jim
My DVDLab Guides
DTS-HD Master Audio Extraction from Tsmuxer
By m1ke486837 in forum Blu-ray RippingReplies: 0Last Post: 5th Jan 2011, 20:29 -
what is the main function of audio codec(ac97 chip) present on motherboard
By maass in forum ComputerReplies: 1Last Post: 23rd May 2009, 03:58 -
Easy DVD to MP4/MKV with Dual Audio, 'soft' Subtitles, and 5.1 Audio?
By Grovest in forum DVD RippingReplies: 4Last Post: 3rd Nov 2008, 05:12 -
"Master" Master Audio Volume Control?
By Soopafresh in forum ComputerReplies: 1Last Post: 19th Mar 2008, 09:57 -
Vista - Control panel failed to open with Realtek ac97 unistalled?
By amdk62 in forum Newbie / General discussionsReplies: 3Last Post: 9th Oct 2007, 15:15
