I've been looking around at the forums a lot and converted some of my dvds but had a question. Whenever I use smart ripper, then dvd-avi, then tmpgenc to make the final file... Am I actually retaining the Dolby Digital sound format that was encoded into the dvd? I was wondering this because I was going to by a sound card with an optical out and run it to my receiver..... and if the dolby digital sound isn't kept with this method, is there another way to get the dolby digital sound when converting to SVCD?
Thanks!
Results 1 to 11 of 11
SVCD does not support Dolby Digital or DTS audio.
Buy a DVD burner ... good models now for around $100 or less.
Well I have a "modded xbox" that can play all of those formats thats why I was asking... It has a 120 gig hard drive and was interested in putting movies on it, but with out the DTS or Dolby... I'm not as interested... How spoiled I've become
I don't see how having a "modded xbox" supercedes the need for a DVD burner but ummm whatever.
You can dump the movies on the xbox hard drive.Originally Posted by FulciLivesWant my help? Ask here! (not via PM!)
Dump the movies on the hard drive in a DVD format. SVCD is so obsolete n picky, I cant see any reason in messing about with it.
No one said it did, I'm simply doing it for the fun of it and it comes in handy to have 20 or so movies on the hard drive when I take it places.I don't see how having a "modded xbox" supercedes the need for a DVD burner but ummm whatever.
Why not just encode them in DIVX format and dump them on the XBOX if it's all about quality and the amount of movies you can fit on the drive? The XBOX media player can handle DIVX and other MPEG4-esque compression.
Yes. Just remember to keep the DVD's ac3 and not attempt to re-encode it. All you have to do is mux the ac3 with the avi video. AVI MUX GUI can do this.
I tried to use Simple Divx and it has the option to do the ac3 6 channel and everything worked fine but the audio was quite out of sync? Is that what you mean by not re-encoding it?
Does the SimpleDivx try to re-encode it? I downloaded the AVI MUX GUI and drag and drop the originals files and creates and .mka file but then realized I'm not sure where to go from there.
Dolby Digital 5.1 -> PC input?
By Asterra in forum AudioReplies: 1Last Post: 4th Oct 2011, 00:38 -
Dolby Pro Logic vs Dolby Digital?
By therock003 in forum AudioReplies: 17Last Post: 11th Jun 2011, 19:51 -
Dolby Digital 5.1-ch vs. Dolby Digital 2-ch
By coody in forum DVD RippingReplies: 6Last Post: 21st Jun 2008, 15:35 -
From Dolby Digital AC3 to Dolby Digital Stereo and back
By moviebuff2 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Dec 2007, 19:54 -
How to downconvert Dolby Digital to Dolby Pro Logic II?
By randyharris in forum ffmpegX general discussionReplies: 0Last Post: 2nd Nov 2007, 16:54
