Hey All,
Typical question I guess. My spanking brand new GSA-4082 burns at 2x only. Yes I flashed the firmware with the latest from LG website.
Somebody here posted something saying that drive can "be picky". Can somebody explain it to me? DVD Identifier tells me that my media is 4X but my drive can only burn it at 2X. Does the drive see semething else, or is it trying quickly something and comes up with 2X only.
Another question. The regular computer DVD drive, will it play ( read ) all media (-R, +R, -RW, +RW ) or does it have to be multi read something. Could I play DVD-R video on a regular DVD drive ( you know the $29 one )
And the last one: which format is supported by more stationary players -R or +R? I thought -R so bough a pack of 25, but my APEX 660 won't play them.
Thanks for your time folks,
J.
All brand named like Memorex, Maxell, TDK, Ritek etc will burn at 4X
Cheap media with following media code will burn at 4X with good results
Princo, Prodisc and Longten, Prodisc is the best among the trio and IMO is better than Ritek.
following cheap media will also burn at 4X but better off at 2X, too much error at 4X
AN32 AN35 -
i have the same problem , WHY MY GSA - 4082 JUST BURNING AT 2X ???????????????????
DOES SOMEONE KNOWS THE ANSWER ???
my icq - 44984632 -
It is possible that DMA is not enable on your O/S for the 4082, since it will resolve to only 2X in PIO mode, goto control panel and check if DMA is enabled on your IDE channels.
Use this link to show you how to ENABLE DMA IN XP
http://www.cdrlabs.com/phpBB/viewtopic.php?t=7625
lg gsa-4120b dvdwriter
By mustang1967 in forum DVD & Blu-ray WritersReplies: 1Last Post: 29th Jun 2008, 23:50 -
Drive problem- LG GSA-H10L
By pinetop in forum ComputerReplies: 9Last Post: 17th Apr 2008, 01:39 -
Cant update my LG GSA-55L firmware?
By kiaconcepts in forum DVD & Blu-ray WritersReplies: 1Last Post: 28th Jul 2007, 07:59 -
Question about GSA-E60L External
By kiaconcepts in forum DVD & Blu-ray WritersReplies: 1Last Post: 20th Jul 2007, 11:27 -
Video capture with LG GSA-5169D
By henrik.uggla in forum LinuxReplies: 2Last Post: 25th Jun 2007, 15:59
