Well, the title says it all, pretty much.
I'm using Win XP Pro.
I am importing VRO files from my Panasonic DMR-E50. I change the extention to MPEG so that I can use the files in UMF3. When I go to set chapter stops, I can usually set two or three before the system locks up. Before starting this, I shut down all non-essential programs, but it doesn't seem to help.
The raw file size is usually about 2Gb (I'm transferring my Star Trek Animated Series from laserdisc).
Any clues on how I can stop this?
Thanks!
PS: I don't have a problem doing the same thing using TMPGenc.
Results 1 to 1 of 1
Resampling quality setting in Ulead VideoStudio
By eclipse95 in forum Video ConversionReplies: 20Last Post: 16th Sep 2009, 21:08 -
How do I remove chapter stops?
By Ronny G in forum Authoring (DVD)Replies: 5Last Post: 9th Apr 2009, 08:42 -
GUI for dvdauthor - How to make chapter thumbnails run the chapter video
By deco81 in forum Authoring (DVD)Replies: 4Last Post: 15th Dec 2008, 12:51 -
Video stops after intro - is it a chapter-problem or just corrupted?
By offtherecord in forum Software PlayingReplies: 2Last Post: 21st Nov 2007, 10:38
