I have an audio track that I'm trying to "fix" and am wondering if there's a specific filter anyone might recommend.
Here's the deal: It sounds like the audio was originally captured "in the red". It's got a slight distortion to it, like it was captured at a too-high volume level.
When I open it in Goldwave, it shows the dB level to be at -19.50, which is fairly low.
So my presumption is that it was captured at too high of a volume and then some sort of Normalizing was used which brought the dB level down.
Is there any way to fix this with a filter?
Thanks.
if you mean you want to raise the volume because it's too low, sure.
if you want to remove the distortion, not really - if parts of it are distorted, you can lower the level on those parts so they match the rest of the track and don't stick out as much, but if everything is slightly distorted, you can't really undo it.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light" -
Yeah, the whole thing is kinda distorted. Oh well... I'll track down the source and get it done right.
Thanks for the reply.
Audio Hiss Problem--I tried audacity
By bbbbbbb45 in forum AudioReplies: 16Last Post: 15th Apr 2012, 08:55 -
Just getting started on audio--removing a squeal with Audacity
By solarblast in forum AudioReplies: 13Last Post: 14th Mar 2011, 11:17 -
Why does Audacity always save audio files differently?
By sldvd in forum AudioReplies: 15Last Post: 22nd Nov 2010, 14:17 -
How to set streaming audio input to Audacity?
By edDV in forum MacReplies: 2Last Post: 25th Aug 2008, 13:19 -
Cleaning Up MPEG-2 Audio via Audacity
By cyberboy in forum AudioReplies: 4Last Post: 25th Aug 2008, 02:26
