Anyone?
The size option on DrDivX is very important, but the filters on VirtualDub make all the diference.
Well, I can't mix then, can I?
Don't think so.
Anyone knows where I can find DrDivX filters?
Or, a way to use VirtualDub filters on DrDivX?
If you know how to use Virtualdub just ditch Dr. Divx entirely. Vdub is a much better encoder anyway. I would only use Dr. Divx if I couldn't use Virtualdub. It's good for newbies but that's about it.
But, I'm not an advanced user, that's why a posted here. In the newbie section.Originally Posted by teegee420
But, anyway, thanks.
Anyone else can help me? -
The two are mutually exclusive and cannot share filters.
If you find that drwhosit can't do what you want, then it's time to learn more advanced tools.
Virtualdub is as good as it gets (almost) for editing avi's, and it's also free.
The built in filters are excellent, and there are a few other great ones floating around on the web. It depends on exactly what you want to do with your video.
Size is one of the basic vdub filters, and easy enough to figure out.Cheers, Jim
My DVDLab Guides -
There are lots of guides for Virtualdub. Now is as good of a time as any to learn. If you get stuck, you know where to post your questions.
Could I get some advice on which VirtualDub filters to use?
By ryangarfield in forum RestorationReplies: 8Last Post: 1st Jan 2011, 01:26 -
[Solved] Question about MPlayer filters in FFDShow and Mencoder filters
By BlooderButcher in forum Video ConversionReplies: 4Last Post: 24th Nov 2008, 12:32 -
import VirtualDub filters into Vegas?
By Srivas in forum EditingReplies: 8Last Post: 8th Oct 2008, 06:49 -
question about virtualdub resizing filters
By gutsmanx in forum Capturing and VCRReplies: 2Last Post: 30th Aug 2007, 13:55 -
virtualdub filters
By demonwarrior in forum EditingReplies: 5Last Post: 9th Jun 2007, 06:27
