I have resigned myself to posting in the newbie forum, because my (seemingly) advanced questions turn out stupid, so here goes.
I can frameserv from virtualdub to TMPGEnc (very old) beta 12.
Not the best. I don't have the options I would like as in tmpgenc plus 2.5
If I try to frameserve to tmpgenc plus, it crashes.
If I try to frameserve to Canopus Procoder, it crashes.
If I try to frameserve to Mainconcept, it crashes.
Anyone have any idea how I can frameserve from virtualdub to anything besides the ancient version of tmpgenc?
Ideally, it would be nice to use Mainconcept, however...it's getting tiresome having to either wait 16 hours in tmpgenc, or save an intermediate avi to encode in Mainconcept (which is actually MUCH faster).
Results 1 to 14 of 14
Cheers, Jim
My DVDLab Guides -
I'm not really a user of VDub frameserving but there's something i've been wondering about.
On a WinNT and up system, shouldn't these files be in the System32 directory?
Could this be your problem? (a Wild-Ass-Guess) -
Perhaps not. I run XP and don't have any problems frameserving with Vdub, except to Mainconcept. It only gives me a green screen.Originally Posted by au7usa
Confirmed! I just tried it....works just fine in the System directory.
Must be something about your configuration.
Did you check the guides:
https://www.videohelp.com/virtualdubframeserve.htm#problems
https://www.videohelp.com/forum/viewtopic.php?t=87293&highlight=msvcr70%2Bdll -
I did a quick edit, refresh your page.
(me stupid, but me fix now)
All good now? -
I've tried everything. Reinstalled it all, tried the proxyon and off, tried the various .dll's and three different versions of virtualdub.
None of them will frameserve to tmpgenc plus 2.5 yet all will frameserve to my old beta.
None of them will frameserve to Mainconcept 1.4 nor Canopus.
Going to reformat/reinstall soon, and if THAT doesn't cure it...
Cheers, Jim
My DVDLab Guides -
There is a workaround for frameserving with Virtualdub to apps that dont support VDR files as input. Use AviSynth to load the VDR then load the AVS file in any encoder. Works every time. And btw, the function to open VDR is AviSource("c:\myvdub.vdr").
thor300, Perfect!
Another half hour cut off my production time
Teegee:Anything that requires scripting in this day and age of GUI's...a very apt descriptionKind of like coockroaches after a nuclear holocaust.
Cheers, Jim
My DVDLab Guides -
Uh... have you checked your environmental settings in TMPGenc?
Look, let me explain something. I'm not Mr. Lebowski; you're Mr. Lebowski. I'm the Dude. So that's what you call me. That, or Duder. His Dudeness. Or El Duderino, if, you know, you're not into the whole brevity thing-- -
Been there, done that, got the T-shirt.
Even installed a second instance of tmpgenc to compare the two. One default, and one to mess with.Cheers, Jim
My DVDLab Guides
Frameserving From VirtualDub to MainConcept
By hech54 in forum Video ConversionReplies: 0Last Post: 8th Mar 2012, 10:24 -
frameserving, from premiere to autogk
By codemaster in forum EditingReplies: 0Last Post: 26th Dec 2010, 20:57 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 14:26 -
FrameServing from Vegas 9 to MeGUI
By Kit-10 in forum Newbie / General discussionsReplies: 8Last Post: 4th Dec 2009, 18:12 -
Frameserving Options?
By echo1434 in forum ProgrammingReplies: 0Last Post: 9th Sep 2007, 22:31
